Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 03:23 PM   #1
Electrical
I am trying to switch out my 3 way light switch with a GE Smart Digital Timer Model # 15071. My GE Smart Digital Timer has 4 wires Red, Black, White and Green. My original 3 way Switch had a Red wire on the top right, aa Black Wire on the Top left, a Black Wire at the Bottom Right and a bear copper wire at the bottom left around a green Nut. I also have a bundle of White wires tied off in the back of the electrical box. I am trying to determine which wire goes to which wire. The instructions do not say anything about a red wire from my electrical box and I'm not sure which black wire is the load and which is the main power. Can anone help??
Bernie H is offline   Reply With Quote
Old 12-27-2010, 03:32 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
That is a single pole timmer and will not work in 3 way setting.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 12-27-2010, 03:36 PM   #3
Electrical
So, when I go back to the store I should ask for a single pole timer??
Old 12-27-2010, 03:41 PM   #4
jbfan's Avatar
Rewards Points: 980
No, you need a 3 way timer.
Old 12-27-2010, 04:53 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you have the packaging or literature that came with this switch? I haven't looked it up but it sounds like the timer I have and it can be used with a single pole or 3 way switch. I don't remember the wiring at the moment. Will have to look for it
Old 12-27-2010, 07:16 PM   #6
jbfan's Avatar
Rewards Points: 980
http://www.jascoproducts.com/support...Manual-eng.pdf
This is what I found on that timer.
Old 12-27-2010, 08:50 PM   #7
nap
You talking to me?
nap's Avatar
Now that I'm awake and I re-read the post, I agree with your advice.
Of course mine has a second colored wire.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
