Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 06:09 PM   #1
electrical
built addition to house.all open .need 6000watts of heat on one low voltage thermostat.Put relays by panel. What is the best way to do it?
kcleary is offline   Reply With Quote
Old 06-29-2010, 08:11 PM   #2
I=E/R
a7ecorsair's Avatar
Do you have relays that have a coil voltage of 24V AC? Do the relays support 30A resistive load? Is the relay a double pole relay?
In my house the relays are mounted inside the circuit breaker panel and the thermostat wire runs to this relay.
a7ecorsair is offline   Reply With Quote
Old 06-30-2010, 12:41 AM   #3
" Euro " electrician
frenchelectrican's Avatar
I will make it quick and simple .,
You will need.,
24 volt transfomer IIRC 60 VA size( 40VA is bare bone minuim size if you only have one relay ) { do not use standard door bell transfomer it may not have enough wattage to pull the relay in.
6X6X6 steel or plastique junction box { it should be big enough to get the relay fit in other wise some relay will slip thru the half inch KO's then change the box size to 4X4X2 1/8.
Normally I rather keep the relays next to the panel so it easier to find it when you have issue with the relay[s].
But I know some case you may find 30amp rated line voltage thermosat that will work equally well { sometime it will be cheaper and quicker than use the low voltage thermosat plus relay } but check out the price on them.
Merci.
Marc
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
