Electric Water Heater Element.... - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2014, 06:38 AM   #1
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Electric water heater element....
This post is just for general knowledge, just a service call I went to and how I resolved the problem....
Problem was a point of use electric water heater, 120 volt / 1500 watt element not working. Tested the element, and found that to be the culprit. Now, my next problem was I brought with me some random replacement elements, but I didn't have a 120v element, but I did find a 208v /4500w element, after some basic ohms law calculations, this element would draw around 1440 watts, not a bad replacement for a water heater with limited demand.
This is just a temporary replacement until the guy purchases a new water heater, but glad I was able to get him up and running with the limited options I had at hand.
The Following User Says Thank You to stickboy1375 For This Useful Post:
micromind (08-03-2014)
Old 08-03-2014, 06:45 AM   #2
Rewards Points: 1,832
Excellent post Ive done it before with AHU heater coils, once you know how the math you win every time.
Jump-start is offline   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
Old 08-03-2014, 06:47 AM   #3
E2 Electrician
I had a helper with me that looked at me like I had two heads....
Old 08-03-2014, 06:59 AM   #4
Just make sure you tell him it only works for a pure resistance. Inductive loads would be bad
Old 08-03-2014, 07:01 AM   #5
E2 Electrician
Ha, very bad.
Jump-start (08-03-2014)
Old 08-03-2014, 11:31 AM   #6
Idiot Emeritus
Rewards Points: 80
I've done this too......more than once.......and not just water heaters........
Actually, this has increased the longevity of the element because it now has a lower watt density (there's more surface area to dissipate the heat) and the resistor inside will run cooler.
One possible problem here is that the 4500W 240V element might be too long to fit in the tank.
micromind is offline   Reply With Quote
Old 08-03-2014, 11:37 AM   #7
E2 Electrician
Originally Posted by micromind
I've done this too......more than once.......and not just water heaters........ Actually, this has increased the longevity of the element because it now has a lower watt density (there's more surface area to dissipate the heat) and the resistor inside will run cooler. One possible problem here is that the 4500W 240V element might be too long to fit in the tank.
Yes, I had 240/ 4500 w elements, and they were too long, that's why I went with a 208/ 4500w element, fit perfect.
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 04:45 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Can I replace 4000w water heater element with 3800w? TitaniumVT Plumbing 6 11-30-2010 06:01 AM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 12:11 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 01:51 PM
