Electric Tankless Hot Water Heater 30amp Instead 40amp Breakers - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 07-20-2019, 08:29 PM   #31
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Re: Electric Tankless Hot Water Heater 30amp instead 40amp breakers
If you run individual conductors it must be in conduit the whole run.
Adding up the breaker handles I'd meaningless.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 07-20-2019, 08:48 PM   #32
Super Moderator
joed's Avatar
Rewards Points: 29,218
If you run in conduit you only need one ground, not three.
Old 07-20-2019, 09:45 PM   #33
Rewards Points: 324
currently
Thank you, I didn't know that but was planning to run in conduit just because it seemed safer however
I was planning to run in conduit from the unit through a plywood false, 2nd, wall that the unit is mounted on, wire up the inside of that wall using cable ties to keep it together, then in to existing 1 1/4" PVC piping at the top which currently exits not in conduit, current is Romex cable stapled to the floor joists. I can put it in 1" electrical conduit, would pvc be ok? Then how close to the panel can I stop? At the top? Do I have to run it in to the box using one of those threaded conduit with the electrical nut lock?
JLawrence08648 is online now   Reply With Quote
Old 07-20-2019, 10:16 PM   #34
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
The conduit must be continuous and connect both to the electrical panel and the water heater. Running cable would be easier.
Sent from my RCT6213W22 using Tapatalk
Old 07-21-2019, 06:51 AM   #35
Rewards Points: 2,122
I wonder will this WH be within the 50 ft. "line of sight" disconnect rule, from the breaker box it is being powered from ?
Gregsoldtruck79 is offline   Reply With Quote
Old 07-21-2019, 07:59 AM   #36
Property Mgt/Maint
Rewards Points: 6,884
Since you told us in post #30 that the house has gas run to it, someone should really evaluate why this energy suction machine is even here. And do you really want to put another dollar into it!
I can't imagine the gas rates are extraordinary high in NJ.
At this point you are about to spend enough on re-wiring and conduit to nearly cover the cost of a NG tank.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 07-21-2019, 08:18 AM   #37
Rewards Points: 324
Can I buy 8/2 without a ground?
I was thinking running 3 - 8/2 without a ground, using both 2s as a hot, tagged, then the 4th using 8/3 so the ground would be connected.
Old 07-21-2019, 08:21 AM   #38
Rewards Points: 324
The basement has been finished, there are walls in the way now, and corners to turn.
Old 07-21-2019, 08:31 AM   #39
Rewards Points: 324
Gas is cheap here because of gas distribution pipes coming across the country. The house is actually across the river in PA and burn has and electricity are even cheaper.
I was not part of the choice of but water heaters. She previously had a regular hot water heater and choose a tankless. I was shocked when I saw an electric when she had a gas pipe a few feet away, maybe 7'-10', in the ceiling. Now the ceiling is finished with sheetrock but it is a dropped sheetrock ceiling. I can see the pipe on a step ladder from the under steps closet I'm sheetrocking where the electric tankless hot water heater is located.
I set her an email about throwing the money in to a gas tankless heater. She's in Maine for the summer.
Yodaman likes this.
Old 07-21-2019, 10:11 AM   #40
Rewards Points: 58
Sounds like it is indeed connected correctly in the heater minus wrong wire size, just that the white wire needs to be moved from the neutral bar onto the other pole of a 2 pole breaker instead of a single pole breaker. What size service does she have? Having 1 circuit not in the same panel sounds like a problem in the service being adequate.
Wiredindallas is offline   Reply With Quote
Old 07-21-2019, 10:17 AM   #41
Rewards Points: 58
Remember that a gas tankless heater requires a larger than normal gas line compared to a conventional heater.
Old 07-21-2019, 10:50 AM   #42
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
No you will not find 8-2 without ground. Just run 8-2 (with ground) and tie all the grounds together.
Old 07-21-2019, 11:29 AM   #43
Someone correct me if I am wrong here, but I am so far seeing these issues with the OP's WH project.
1. Needs all new # 8 service conductors. Doable...
2. Is currently fed from TWO different breaker boxes. Not good ...
3. Is a electricity hog. Not good....
4. The breaker box is not in sight of the WH, so there will be no legal means of disconnect at the WH for servicing. Not good....
5. Has it been confirmed the service to this dwelling is safe to handle this WH ?
IMO, unless Sis is housing 6-9 people she could probably get by with a standard gas 50 gallon WH. If she does have a lot of people steadily in the homes showering, she would probably do well with a 75 gallon WH like in the link.
But I can certainly see why no one likes dumping probably a $1500 (???) WH, they already have paid for just to buy another WH and have to pay to get installed. But the ROI even after 10 -12 years may be worth it. No utility prices are going to go down, gas or electric. . JMO
https://www.hotwater.com/Water-Heate...ater-GPVX-75L/
Old 07-21-2019, 12:25 PM   #44
Rewards Points: 324
No I did not know that. Another problem maybe to deal with. I'll just tell her to move. Looking at the pipes inside the ceiling, I think it may be large enough as I noticed it had a line that was reduced going to the gas stove.
What size will I need?
Old 07-21-2019, 12:59 PM   #45
Rewards Points: 324
OP - Agree, initial reason for posting, Thanks everyone!
OP - I don't like that idea either but why not?
OP - She was complaining about her electric bill. I was going tho ask her what it was before the tankless. She had a large electric regular tank heater. I'm thinking about maybe owning a solar system might be the way to go for her.
OP - ??? Legal means of disconnecting the water heater for servicing?? Legality? Just walk 35' open the door to the panel. Why does it need to be in sight?
5. Has it been confirmed the service to this dwelling is safe to handle this WH? is
OP - It's been there for almost 2 years without a problem.
See my replies above after OP
