Electric Stove Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 11:30 AM   #1
Retired NYPD
Electric stove wiring
I have an electric stove that the tag says is 10 kw, and 120/240. What size wire ga. Do I need? Is it 8 ga. Or 6 ga.? And 3 wire. I was told it needs a 50 amp circuit breaker.
FrankLa is offline   Reply With Quote
Old 01-01-2012, 11:42 AM   #2
Licensed electrician
Rewards Points: 3,740
New installs need to be 4 wire. The allowance for 3 wires ended in the 90's.
Old 01-01-2012, 12:12 PM   #3
Retired NYPD
What gauge wire
Jim port, what gauge wire should I use? 6 or 8 ga.?
Old 01-01-2012, 12:19 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 328
10KW / 240 = 41.7 amps
#6 wire or cable with 50 amp breaker
4 wire circuit required.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 01-01-2012, 12:22 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
A 10kw range/stove can be on a minimum 40 amp branch circuit using 8 awg copper. However future upgrades could be stoves/ranges with more power useage. Generally speaking ranges/stoves 12 kw and above should be on 50 amp branch circuits or more. So your choice is to wire for the range/stove you have or wire for any future upgrade.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-01-2012, 01:06 PM   #6
Retired NYPD
What gauge wire should I use? 6 or8 gauge?
Old 01-01-2012, 01:45 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
#6 copper with 4 conductors
plummen is offline   Reply With Quote
de-activate 220v electric stove outlet 6fthook Electrical 17 10-04-2011 06:32 PM
Electric Water Heater Wiring tech14 Electrical 6 09-23-2011 01:53 PM
Wiring for electric range rgustavw Electrical 2 09-21-2010 02:18 AM
Wiring Stove from Switch Box sleepysmurf Electrical 3 08-12-2010 04:54 PM
Electric wiring AMPIN88 Electrical 1 02-21-2009 10:31 PM
