Electric Salamander Heater 240 Volt 1 Phase 63 Amps - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2015, 11:29 AM   #16
Rewards Points: 1,588
better to get some portable 4800 or 5600 watt heaters that sold for about 100$ each. only needs 30A outlet each
carmusic is offline   Reply With Quote
Old 01-09-2015, 11:45 AM   #17
Rewards Points: 4
Thanks all, electrician pulled a coil out via 2 fuses and unit is only producing 7. 5 kW, wired it to a 50amp plug and all is well. Portable for the shop and basement for heat as needed.
learnites is offline   Reply With Quote
Electric heater and venting and freezing jackwashere Appliances 2 09-28-2012 06:51 PM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 12:11 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
