Electric Radiant Heat In The Shower? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 03:42 AM   #16
Electrical Contractor
kbsparky's Avatar
It wasn't cheap. About $350 or so.
But it was better than busting up the floor and replacing those mats.
-KB
Old 03-12-2010, 05:48 AM   #17
Just call me Andrew
Rewards Points: 1,032
Wow...I'm just going to skip the shower. More simple, and the shower floor should get pretty warm anyway with the water hitting it.
Andrew
secutanudu is offline   Reply With Quote
Old 03-15-2010, 06:02 PM   #18
Originally Posted by secutanudu View Post
Watts SunTouch matts are UL approved (according to their site) for use inside a shower. It's 120v, and the heating coils are encased in Pex tubing. I will also be installing a schluter kerdi waterproofing membrane between the heating elements and the tile.
I talked to Suntouch and they said the heat element MUST be embedded in the same thinset that holds the tile - in other words the heat element goes on TOP of the Kerdi.
Quickdraw is offline   Reply With Quote
Old 03-15-2010, 06:49 PM   #19
Just call me Andrew
Ah, well that'd make me too nervous. I already ordered the mat to fit my bathroom other than the shower.
Good info though, thanks.
Andrew
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
Tiling over mosaic (1954) with electric radiant heat? ControlTech Flooring 2 02-04-2010 08:01 PM
Underfloor radiant electric heat dangdang Electrical 9 09-26-2009 11:49 AM
Better for heat pump or electric coil/strip? Lori 48616 HVAC 5 09-05-2008 02:28 PM
