Electric Golf Cart - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 12:55 PM   #1
Electric Golf cart
I have a electric golf cart that runs on 14.4V 10000 ma.
The problem that I have is I can't replace the battery with the same.
I can get batteries that are 12V but the amperage I would like to use is 24 amps.
My question is can I run the cart with the 24 amp battery. The power is routed thru an on off switch , thru a ciruit board up to a rotary speed control on off switch then down to the motor.
Thanks to anyone that can help
gibber is offline   Reply With Quote
Old 12-23-2009, 02:42 PM   #2
The higher the amp-hour battery capacity, the longer the run time. If you get two hours out of a 20 A-h battery, you should in principle get four hours out of a 40 A-h battery.
Two 6v batteries in series at 24 A-h each gives you a 12v 24 A-h battery.
The cart circuitry is only concerned with peak and average current draw, which is not very related to battery capacity.
Old 12-23-2009, 02:43 PM   #3
Rewards Points: 1,016
What is the vendor / model of the orginal battery the golf cart manufacturer calls for?
Old 12-23-2009, 05:53 PM   #4
As mentioned the original was 14.4 V 10000 ma ( 10)
Old 12-23-2009, 06:01 PM   #5
That's what I thought but I hooked it up to my Van battery and I cooked the curcuit board. I kind of think I got the + & - reversed.
Old 12-23-2009, 07:02 PM   #6
If this was in responce to the question of vendor / model, this is not the vendor / model, rather voltage and capacilty... I was interested in vendor / model as the voltage and capacity stated seem rather odd from the norm.
Old 12-24-2009, 09:16 AM   #7
Yes it is an odd voltage. The Cart is the Hawk Golf Caddy U can google it but it is no longer being made and the battery for it is 14.4 volt 10000 ma. which also is no longer available. You can have it rebuilt for $300 , I don't think so.
Hope this clears things up
Old 12-24-2009, 01:15 PM   #8
Household Handyman
Rewards Points: 1,412
May I offer this advice, with good intentions: I also own an older golf cart, an '87 E-Z-GO which was a basket case when I paid a few dollars for it. This forum offers great advice for DIY people, BUT- I highly recommend that you look into the golf cart forum at "www.Buggies Unlimited.com". The people on there are the golf cart guru's for all types of carts. I'm not saying you are in the wrong forum to get answers, but they are "golf cart specfic". Those guys offered me so much advice as to how to get my cart back up and running, and now I'm the Grandkids "just coolest" Granddaddy. Good Luck, Merry Christmas, David
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 03:16 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 01:11 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
