Electric Bill Broke The Bank - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 07:07 PM   #1
Electric bill broke the bank
I usually have pretty low electric bills, except for the summer of course. However, this year, my bill sky rocketed about 30% higher. I suspect a rougue appliance, probablly my refridgerator. It seems to be running to much, but I can't be sure. I keep the coils clean. How can I test the fridge and other appliances? Electric company wds.
farmerde is offline   Reply With Quote
Old 09-17-2009, 07:17 PM   #2
Kill A watt meter can be used to test power use over a day or two
Do you have a well/pump?
Are you comparing actual Kw hours used, or just the cost $$
Old 09-17-2009, 07:31 PM   #3
Both! Kh was 2365, and bill was about $560. My bills used to average about $300 to $350 during summer months, about $90 during non-summer months. It's breaking my bank. Can that device be used for big appliances?
Old 09-17-2009, 07:42 PM   #4
Device only works on 15a, another one works on 20a devices
Not sure of one for 240v
So 2365 kwh now, what was the last one?
Check ALL the rates, my bill breaks out every charge
Charge for delivery
Charge for electricity
There are like 5 charges all together
And the POCO recently asked for rates increased (20% or more)
A well pump if leaking/problem will run a LOT more
Old 09-17-2009, 09:24 PM   #5
Rewards Points: 3,034
(copied from another post)
A water heater will run up a huge energy charge if you have leaky faucets or pipes in the hot water side of your plumbing.
Is yours electric?
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 09-17-2009, 09:36 PM   #6
Nope. That's what drives me crazy about California. All of our major appliances are on gas (dryer, oven, water heater) and our bills are still higher than most of the country. And no I do not have a well.
Old 09-17-2009, 09:51 PM   #7
Rewards Points: 1,016
I recieved and outsized bill - about $200 over norm. Found I had a pool pump timer that was messed up and running excessively. Replaced the timer and the bills are back to normal...
Old 09-17-2009, 09:51 PM   #8
Charge for delivery
What about the miscellaneous taxes and fuel charges that the utility rate specialists slip in one way or another. What I do is I divide the NET charge by usage. Also, there's a possibility that the meter reader (person) misread one of the Five dials, slipping you in an additional One Thousand KWH. A good thing to do is call the PoCo. They have a program that keeps track of your usage pattern. If it's unusually high or unusually low they will know about it. Happened to me one time. My electric bill was One Hundred dollars higher than usual. Called the Electric company. they told me the bill was incorrect. They canceled the bill and sent a new, corrected version. (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 09-17-2009, 09:54 PM   #9
electric bill
Does your utility company have any kind of audit that they will do (for free, we hope!) that would shed some light? Believe it or not, some are pretty good at helping you trim your bill.
Allison1888 is offline   Reply With Quote
Old 09-17-2009, 09:55 PM   #10
Yeah - I had gas use "estimated" at my last house
They estimated 1 months at what I used for 6 months
I refused to pay, took them 3 months to straighten out
Old 09-17-2009, 10:04 PM   #11
Rewards Points: 46
Is there something that can go wrong with a central air system that can cause an electric bill to jump like that? Maybe it's working harder than it should be for some reason?
We get bills that are unusually high a couple times a year. Just like Spark Plug said, we call the power company and they figure it out almost right away and send us a new bill.
gma2rjc is offline   Reply With Quote
Old 09-18-2009, 06:22 PM   #12
Check out this for monitoring power:
http://www.theenergydetective.com/st...s/ted1000.html
Plumbvoltage is offline   Reply With Quote
Old 09-18-2009, 06:53 PM   #13
Use your wattmeter as an ammeter and isolate the source.
http://en.wikipedia.org/wiki/Electricity_meter
Amps = watts/240v.
Also, your PoCo might just be checking if you are vigilant. You wouldn't believe the [email protected] the GaCo tried to pull on me.
Think YOUR electric bill is high? wfischer Electrical 63 11-02-2009 07:50 PM
High electric Bill? HautingLu General DIY Discussions 9 08-28-2009 12:39 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Help! Electric bill too high, what can I do? pirategirl007 Electrical 24 01-19-2009 10:35 AM
Very high electric bill. 68MHJCs Electrical 58 08-08-2008 08:48 PM
