Electric Baseboard - Electrical - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 12-13-2016, 10:03 AM   #1
DAVI65's Avatar
Rewards Points: 78
Electric Baseboard
I installed two Electric baseboards in my house but the heat turns on and stays on for a litter bit 4 to 5 min then turn off. How do I get this heat to stay on all the time ? I don't understand why the heat turns off.
Notes:
48-inch baseboard
120v - in the circuit with 20amp
Electric Baseboard-20161212_163957.jpg   Electric Baseboard-20161212_171517.jpg   Electric Baseboard-20161212_154211.jpg
DAVI65 is offline   Reply With Quote
Old 12-13-2016, 10:33 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 22,536
Re: Electric Baseboard
Is that a thermostat? Is the temp turned up?
Is there another stat on the baseboard itself? Is it turned up?
Old 12-13-2016, 10:59 AM   #3
DAVI65's Avatar
Rewards Points: 78
Notes:
48-inch baseboard
Yes. The Picture with the wires is the thermostat. Yes gets hot very hot, but after that will turn off and take long time and then to turn on again. the problem is that gets cold to touch.
No orther thermostat on the baseboard.
Old 12-13-2016, 11:04 AM   #4
DAVI65's Avatar
Rewards Points: 78
This is the thermostat
Old 12-13-2016, 11:09 AM   #5
Rewards Points: 766
Not a good place for the thermostat. It shouldn't be above the source of heat. It may just be shutting it off early.
Mikeron and supers05 like this.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
mpoulton (12-13-2016)
Old 12-13-2016, 11:16 AM   #6
DAVI65's Avatar
Rewards Points: 78
I dont understand. The thermostat its above the heat. where should it be ? its there.
Old 12-13-2016, 11:19 AM   #7
Rewards Points: 766
Not above the heat.
You normally want it on an interior wall away from any direct sunlight, vents, heat sources, etc. It should measure room temp, not the temp of the heat source.
The heater is likely heating the air well over 100f and the thermostat is directly above that.
J. V., Jim Port and supers05 like this.
The Following 2 Users Say Thank You to AandPDan For This Useful Post:
mpoulton (12-13-2016), supers05 (12-14-2016)
Old 12-13-2016, 11:30 AM   #8
DAVI65's Avatar
Rewards Points: 78
Not above the heat.
I get.. that may be the problem. Can I used another type of thermostat.. but needs to be on the wall.
Old 12-13-2016, 12:08 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,082
Ayuh,.... No need for a different t-stat, ya just can't put any t-stat directly over the heatin' unit,...
Simple physics,... Heat rises,...
Old 12-13-2016, 12:09 PM   #10
Rewards Points: 424
The thermostat is to read the room temperature and turn the heat on according to the setting you select for the room. If you put it above the heater it will feel the heat coming from the heater and turn it off, it's functioning properly you have just installed it incorrectly. Move it away from the heater and reconnect it and all should be good, oh and make sure it's on an interior wall. Installing on an exterior wall may have the opposite effect of turning it on too much.
Jim Port likes this.
KC_Jones is offline   Reply With Quote
Old 12-13-2016, 12:10 PM   #11
Rewards Points: 766
The problem is the location of the thermostat, not the type.
What about putting it on the opposite side of the doorway, in the same room?
Old 12-13-2016, 12:11 PM   #12
Rewards Points: 424
Hot AIR rises. "Heat" moves to cold.
Old 12-13-2016, 12:18 PM   #13
Bondo's Avatar
Ayuh,.... If ya heat air, it rises, Right,..??
If ya heat water, it rises, Right,..??
If ya heat oil, it rises, Right,..??
If ya heat wax, it rises, Right,..??
In the case above, the heated air rises, turnin' the t-stat off,....
I stand by my statement,....
Heat rises,....
Old 12-13-2016, 03:08 PM   #14
DAVI65's Avatar
Rewards Points: 78
Dan,
How that can be ?
The baseboard is complete cold and the thermostat do not kick in. Its something else wrong and its not the position.
Old 12-13-2016, 03:34 PM   #15
Super Moderator
joed's Avatar
how long do you have to wait before the heater will come on again?
You said it gets very hot. Are you sure it is the correct voltage? You don't have a 120volt heater connected to 240 volts do you?
Electric Baseboard Heaters Always On.. volvik Electrical 15 01-23-2013 01:50 PM
1 Electric Baseboard is Out, advice? agentphish Electrical 18 01-05-2013 09:49 AM
Electric baseboard not working secutanudu Electrical 53 01-23-2012 06:34 PM
Electric Radiant Baseboard and Built-in Bookshelves arobin HVAC 4 07-08-2009 05:42 PM
