Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 12:01 PM   #1
electric
i pluged something in now i lost power in 6 outlets an 2 lights i checked all breakers are good an what do i do next i also changed the outlet an gfi are good
david barker is offline   Reply With Quote
Old 01-01-2012, 12:05 PM   #2
Licensed electrician
Rewards Points: 3,746
You have a loose or failed connection. Look at the last working or first non-working device. I would start where she plugged into.
plummen (01-01-2012)
Old 01-01-2012, 12:15 PM   #3
the Musigician
DangerMouse's Avatar
....and look to see if there's a GFCI involved anywhere in the line and if it's been tripped.
DM
Old 01-01-2012, 12:21 PM   #4
i changed the outlet it still not working
Old 01-01-2012, 12:23 PM   #5
Julius793's Avatar
Check the breaker to make sure it has power.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-01-2012, 12:26 PM   #6
i changed all breakers
Old 01-01-2012, 12:26 PM   #7
The problem could be upstream from the one you changed. Did you check for power before you changed it?
Old 01-01-2012, 12:27 PM   #8
Julius793's Avatar
Ok once you changed it did you test the screw to make sure it has power?
Then find the first place it sends power to Ect..
Old 01-01-2012, 12:28 PM   #9
yes i checked
Old 01-01-2012, 12:29 PM   #10
yes i checked
Old 01-01-2012, 01:00 PM   #11
the Musigician
Sorry, that's not allowed here. For your privacy and safety more than ours!
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
frenchelectrican (01-01-2012)
Old 01-01-2012, 05:00 PM   #12
" Euro " electrician
frenchelectrican's Avatar
David.,
Let start with basic.,
Do you have a simple test light or voltmeter with you ? if not go to the big box store and grab one of them each and they are less than 15 Euros ( dollars )
Next step is you have to " trace " the circuit what room this serves and I will do the receptale checking and also check the wirenut connection to make sure they are tight and MAKE sure the power is off when you do this test for your safety sake.
What room which the circuit is out ?
The reason why I asked due there are few tricks up my sleeves and what era this house built and did have semi modern wiring in there ? ( that will help alot to pin point where the source is )
And also belive or not most older home for the circuit the first thing it will arrive from fuse box or breaker is the ceiling luminaire that will be a first place to take a look if everything in that circuit is out. but for newer home or rewired home it will be a 50/50 split.
If you have any backstabbed ( push in ) receptales or switches then move it over to the screws and please make a note how it connected before you make that move.
Merci.
Marc
Upgrades for my old electric furnace? alochin HVAC 6 09-11-2011 06:09 PM
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 03:37 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
