Electic Water Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 12:16 PM   #1
electic water heaters
what is a reasonable thermostat temp. in a household of four adults.taking half hour long showers? I am helping a friend who's water is scalding hot!
Kishthunderbird is offline   Reply With Quote
Old 10-31-2010, 12:28 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 958
MIne is set just above 120
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 10-31-2010, 12:40 PM   #3
Rewards Points: 2,800
You will have to experiment with it.
The hotter the water is heated in the tank, the more warm water and generally the longer runtime you can get by mixing in more cold water at your shower head.
But for household use, 120 degrees F is the maximum recommended if you have small children.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Tankless Heaters on hard water Pstein Plumbing 0 08-25-2010 05:18 PM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 03:57 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
