Eavesdrop Potlights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 08:07 PM   #1
Rewards Points: 152
eavesdrop potlights
I see that new houses have potlights on their eavesdropes.
I want to do the same but im not sure how the setup would be of securing the potligts?
Do i have to buy some new eavesdrops that are pot light ready or wat do i have to do exactly?
humberguy is offline   Reply With Quote
Old 01-07-2010, 08:25 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Well, some details would help.
By "eavesdrops" I assume you mean eaves?
Existing house or new build?
If new what stage is it in?
What do you mean by "buy new eavesdrops"???
Typically I leave a whip and cut the lights in after if the soffit is wood. If it is vinyl then you have to hang the lights before hand.
Old 01-07-2010, 09:31 PM   #3
Rewards Points: 152
a finished house, about 10 years old. I want to put it by the eaves(where the water runs down the ends of the house) im not sure what the exact terminology would be for the eaves.
I see the new houses have those potlights by the eaves. I want to put potlights their, but i dont know if i could possibly put it with the house i have.
Old 01-09-2010, 11:55 AM   #4
Rewards Points: 310
Its called the soffit. The underside of the roof overhang. Yes, recessed fixtures can be installed in the soffit. There is usually not much room in the soffit. You will need to see how much room you have and buy fixtures that fit. They will be installed/mounted with a bracket that spans two roof joists. You will cut a round hole the size of the fixture between the roof joists. The fixture will be adjustable up and down and sideways. Just line it up and install the trim kit. There will be some instructions that come with the fixtures. Then its just a matter of connecting them to a power source.
Note. Wiring the recessed fixtures before installing them will make this job much easier.
Old 01-09-2010, 12:57 PM   #5
Rewards Points: 152
thanks alot, i understand how to install them now.
Old 01-09-2010, 03:08 PM   #6
Rewards Points: 278
Doesn't the cans and/or fixtures need to say for wet location since it is external to the house?
I have seen people use plywood to bridge the area and install the cans though.
DIYGST is offline   Reply With Quote
Kitchen potlights: plan before or after cabinets? Red Squirrel Kitchen & Bath Remodeling 5 07-26-2009 11:13 PM
one switch with 3 potlights rellik Electrical 20 10-29-2008 05:00 PM
