Is It Easy To Install Honeywell Econoswitch? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2015, 08:52 PM   #1
Rewards Points: 221
Is it easy to install honeywell econoswitch?
I am interested in replacing my wall switch for my porch lights so I can program it to turn on/off at time I choose.
I am looking at this one:
http://www.amazon.com/Honeywell-RPLS...l+econo+switch
I read that a neutral wire is required. I know very little about home electric wiring. So what does that mean? There needs to have 3 wires? Hot, cold and neutral?
So, I am just wondering if it is easy to install.
Any idea? Thanks.
homenewbie is offline   Reply With Quote
Old 09-10-2015, 09:01 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,940
It means if you open the switch box only find two wires, both attached to the switch, you can't install it. You must find two or more white wires connected together and not to the switch in the box.
Old 09-10-2015, 09:14 PM   #3
Rewards Points: 221
Thanks.
2 white wires connected end to end to each other?
Old 09-10-2015, 09:14 PM   #4
Rewards Points: 516
If you have a neutral, it's easy to install. I've never sold that model but I've sold dozens of the intermatic counter part (ST01 series). I've never gotten a call back on one so I highly recommend it.
Arrow3030 is offline   Reply With Quote
Old 09-10-2015, 09:22 PM   #5
Rewards Points: 1,428
If you find only two wires (not counting the ground(s)) then you have what is called a switch loop. This is a way of wiring a switch where power goes to the light fixture box, then a cable goes to a switch box which intercepts the power wire. Only one cable is used and so the white wire of the cable is used as a black (hot).
The other way to wire a switch is to have the power go to the switch, then out to the light. Neutral is connected directly and hot is connected via switch.
So, if you find two or more cables coming in then you probably will be able to install that timer.
The timer needs a neutral to power the device. Typical switches only switch the power so no neutral is needed for the switch (the light does) but this timer also has electronics that need to be powered, so it needs a neutral to be able to power the electronics.
The black is hot which carries the power in. The white is neutral which carries the power out. Hot is like positive of DC and neutral is like negative.
poiihy is offline   Reply With Quote
Old 09-11-2015, 05:20 AM   #6
Rewards Points: 402
You also have to have a ground. Hot AC in, AC out, ground are the minimum 3 connections.
Habeed is offline   Reply With Quote
Old 09-11-2015, 08:32 AM   #7
Rewards Points: 221
So, if the box in the wall does not have neutral wire, I won't even be able to use this honeywell econoswitch?
I've tried light-sensor controlled switch like this one:
http://www.homedepot.com/p/Westek-Pr...C9BC/203675443
But, they don't work very well. Lights are on during bright daylight, and there is no way to adjust its sensitivity and had to return to home depot.
So, I am really hoping that I can install something like honeywell econoswitch.
Old 09-11-2015, 12:53 PM   #8
Super Moderator
joed's Avatar
The switch box has to have a neutral for this switch to work. If it doesn't then you have the option to rewire and add one. How difficult that would be depends on the building layout.
Tags
How Easy to Install Wainscoting? Wirks Carpentry 15 09-06-2015 05:44 AM
easy kitchen faucet install question adamhodge General DIY Discussions 4 07-04-2011 09:45 PM
Yet another Honeywell RTH8500 install tayl428 HVAC 2 10-09-2010 09:08 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
