Duplex Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2014, 08:54 PM   #1
Duplex light switch
I have a duplex light switch which is one on top one on bottom. My one on top is named so I have to get a new one. The one on top controls the lights and fan while the one on the bottom controls the outlet that my tv is plugged into. Is there a way that I can make it one light switch but have it only control the lights and fan and have the outlet run on its own? I want to get a belkin wemo switch and can't with a duplex. Thanks
Zkirk99 is offline   Reply With Quote
Old 09-21-2014, 09:13 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,622
Sure that should be simple. The black wire on the bottom going to the receptacle gets connected to the power black feeding the common screw.
Old 09-21-2014, 09:14 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
Take two 6" pieces of black wire and wire nut them to the hot wire from the switch. Run one wire to the switch and the other one gets wire nutted to the wire that goes to the outlet. The whites or neutrals and grounds can stay the way they are.
Robpo is offline   Reply With Quote
Tags
light switch dual
Fan and Light Operate Erratically after install of another switch next to it CHEMTRAILS Electrical 12 10-15-2013 08:25 AM
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 09:11 AM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
