Duel Fed 3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 04:42 PM   #1
Rewards Points: 2,068
Duel fed 3 way switch
Anybody ever heard of duel fed 3 way switches ? takes 2 breakers to kill it to work on it, only has 2 traveler wires between switches with feeds 1. at the light 2. at the downstairs switch. Heard years ago contractor's wiring old houses ran 2 wire between the switches to save money if they had a lot of houses to do.
Example : Old row houses.
Think I just ran into this any help would be appreciated.
COLDIRON is offline   Reply With Quote
Old 11-11-2010, 05:28 PM   #2
Rewards Points: 150
That sounds like some of the stuff I've seen in old knob&tube wiring.
I think I've got a reasonable picture in mind, except that whole part about having to kill two breakers. That part puzzles me.
In any case, it's definitely not legal by current codes.
emolatur is offline   Reply With Quote
Old 11-11-2010, 08:16 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,990
There are strange ways wire three way switches. None of them involve two separate circuits powering them. This is double wrong.
Old 11-12-2010, 04:49 PM   #4
There is old duel feed 3 ways in some old houses, I did not have that I was confused as hell. It is all straightened out now.
The 3 way was powered through the light. At the downstairs switch box it had a 3 way with a single pole switch combination (one on top of the other) the hot side of the switch side had to have the tabs broke off. It also powered a porch light. The 2 breakers are 1. to feed the light upstairs 2. the other one was for the bottom switch that fed the porch light .. Thus the 2 breakers. WOW you can tell I don't do this every day.
If anybody wants the duel fed 3 way diagram I will try to put it up.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
