Dryer Hookup - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2009, 09:58 PM   #1
Rewards Points: 67
Dryer Hookup
I'm getting a new dryer for my home. The existing dryer has wire coming out from the wall. Can I use a 3-wire range cord to install the power connection?
tate16t is offline   Reply With Quote
Old 10-26-2009, 10:11 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Why not use a dryer cord?
Is there are receptacle? 3-hole? 4-hole?
Old 10-26-2009, 10:50 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I am with Speedy Pete
Here what the three conductor receptale look like
Now here what 4 conductor receptale look like
Both can come in surface or recessed verison
let us know if you have one of the two
Merci. Marc
Old 10-27-2009, 09:57 AM   #4
Rewards Points: 67
Merci. Marc
Sorry, I wasn't clear in my post. The existing dryer does not have a cord. It is hard wired via a cable coming from the wall. I understand I need to have a receptacle added and will do so. My question is, do I add a 4 or 3 conductor receptacle? I was under the impression that existing built homes can go with 3.
Old 10-27-2009, 10:29 AM   #5
Licensed Pro
All depends on how many wires are in the cable, what kind of cable it is, and what color the wires are. Can you tell us?
Old 10-27-2009, 10:49 AM   #6
Rewards Points: 67
When I get home later today I will check. I should be able to tell you since the cable coming from the wall connnects to a metal box and then continues to the dryer.
Old 10-27-2009, 07:33 PM   #7
Rewards Points: 67
I'm in NY. The existing dryer does not have a cord. It is hardwired. A cable is coming from the dryer to a steel utility box. The cable coming from the wall is black with a black, white cable and a copper ground cable coming from it. They connect within the steel utility box to the dryer cable. I understand I need to have a receptacle added and will do so. Do I add a 4 or 3 conductor receptacle? I was under the impression that existing built homes can go with 3. Thanks for your help!
Old 10-27-2009, 07:40 PM   #8
That's a three wire. I am pretty sure your neutral should be insulated though.
Might need a new #10 4-wire cable assembly and 30 amp breaker
Penczak is offline   Reply With Quote
Old 10-27-2009, 07:45 PM   #9
Licensed Pro
That wiring is not and never has been the proper for a dryer. Replace it with 10/3 w/ground run directly from the panel, terminated with the 4 conductor receptacle.
Old 10-27-2009, 08:32 PM   #10
I wrote underline there and this is a wrong cable useage for dryer the bare conductor is not used for current carry conductor at all the only time it will allowed is SE cable that it anything else the bet is off with exsting installment but if it was replaced then someone is not paying attetion to the code that time when someone installed the cable.
Merci,Marc
Old 10-27-2009, 09:03 PM   #11
Although it will function safely (my opinion of course), the NM cable you have is not proper for a dryer.
Type SE cable also utilizes a bare neutral/ground but it for some reason is legal in existing circuits.
You have a 3 wire circuit existing. The black and white wires are hot (240 volts) and the bare was acting as the neutral/ground.
If you can replace the cable with a 10-3 with ground back to the panel and remove the bonding jumper in the dryer jbox, you will have a code compliant installation.
My house...eh.
Customers house, I'd tell them they had to replace it.
220/221 is offline   Reply With Quote
Old 10-27-2009, 09:16 PM   #12
Rewards Points: 67
What would be the approximate cost for an electrician to do this?
Old 10-27-2009, 10:29 PM   #13
$200 - $1200.
See my replies on the other board you posted to.
Old 10-28-2009, 09:10 PM   #14
Rewards Points: 67
I'm posting pics...
Old 10-28-2009, 09:17 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,428
Needs to be redone.
Looks like they took and old stove run and used it for a dryer.
The box is too small for the connections, and they connected the bare ground to the neutral wire leaving the box.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 08:16 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 10:45 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
