Dryer Blowing Fuses - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 10-06-2017, 09:21 AM   #1
Rewards Points: 4
Dryer blowing fuses
Hi, discovered dryer won't stop and no heat. Traced problem back to small 2 fuse box near dryer. One of 30A fuses blew. Replaced, dryer ran and then blew one fuse again. Found lint trap was completely covered and also did some research and found someone had issue with corroded contacts in fuse box. Checked and mine looked dark so cleaned them to bare metal, replace fuse again and dryer ran without problem.
I would however like to remove this fuse box and also replace the original dryer wire (house 50 yrs old) with new 10/3 wire. About 12 yrs ago had reno and contractor upgraded fuse panel with breakers, but left dryer wiring as is. Today the dryer is running into that small two 30A fuse box near it and then wire runs to 220v 30A breaker. So dryer is double protected.
I'm just triple checking there is no valid reason to leave the small 2 fuse box, the main breaker is all that is needed. Even though only one fuse blew, the breaker would have tripped correctly had it been the only thing between it and the dryer?
Thanks!
jim56 is offline   Reply With Quote
Old 10-06-2017, 09:53 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,922
Re: Dryer blowing fuses
If your dryer is plug in then you should be able to remove the fuse box. Prior to corded dryers when they were hardwired a disconnect was required at the dryer.
CodeMatters likes this.
The Following User Says Thank You to joed For This Useful Post:
jim56 (10-06-2017)
Tags
dryer , fuse , wiring
New-ish electric hot water heater blowing fuses. roasted Electrical 33 01-11-2017 01:24 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
open neutral on dryer...dryer won't work inspectorman Electrical 32 02-20-2012 02:16 AM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
