Dropping Computer Cable To Basement From First Floor - How To - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-15-2014, 08:58 PM   #16
Rewards Points: 106
Originally Posted by gregzoll View Post
Very little need for hardwired connections now days. Only things hardwired in my house, is the DirecTV DVR & Blu-Ray Player one a switch, a PS3, and the two Access Points upstairs.
Everything else in my place is wireless.
As I said, only dependable way to go is hardwired!
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
The Following User Says Thank You to digitalplumber For This Useful Post:
djlandkpl (04-16-2014)
Old 04-15-2014, 09:14 PM   #17
Rewards Points: 6,652
Hard wired is not dependable. You can still have packet loss in certain circumstances. Majority of homes like my household is. You will find very little equipment that is hardwired. The majority will be wireless.
Old 04-16-2014, 06:59 AM   #18
Bob Sanders's Avatar
Rewards Points: 2,536
Nah. Gotta disagree there. Not that you can't get packet loss, because you can, but I have found wireless to be a bit iffy when streaming bigger files. A 40 gig Blu Ray movie for example with DTShdMA audio just doesn't stream as smoothly through wireless as in hard wire (gigabyte connection). Wireless is great for the handheld devices (phone,tablet... etc) and in fact I do has your previous suggestion above (a combination of the wired/wireless technologies) but for the serious and heavy streaming, hard wire still can't be beat.
There is also a slightly higher security risk with wireless that needs to be considered. Granted, with today's various protection methods, cracking a wireless network is not an easy thing to do. However the more (unnecessary) wireless connections you have in the house, the more vulnerable you become.
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
Old 04-16-2014, 09:07 AM   #19
Rewards Points: 51
Thanks everyone! Just wanted to report that gregzoll put me in the right direction. Took his advice and the project took 10 minutes. We wanted a hardwire connection for stability but we don't always keep our wifi on because of emf(s). When we want to use wifi, we just turn it on, but most of the time it is off, hence we wanted a hardwire connection. Working great, thanks again everyone, glad this forum is here.
abacker is offline   Reply With Quote
Old 04-16-2014, 09:11 AM   #20
Rewards Points: 51
BTW how much do you think we saved DIY? It cost us $38 for the bit. Just curious.
Old 04-16-2014, 12:18 PM   #21
abacker, you get more emf from your tv, and going outside, along with rf & emf from radio & tv stations in your area & from the solar System, then you do from your wifi equipment.
Old 04-16-2014, 05:31 PM   #22
Rewards Points: 3,466
Just want to throw in my penny....
Hardwire is what I do for all networks, because EVERYTHING is on the network, and it needs to be not just stable, but able to operate at gig speeds, which wireless will not do.
To the OP. You MAY have saved around $150.00. But it really depends on how it was done.
ktkelly is online now   Reply With Quote
Old 04-16-2014, 05:35 PM   #23
Wireless does do gig speeds. With Wireless-N multi-antenna and Wireless-ac. You can pull 1.3gbps or more, depending on the file type and distance.
In a residence, Mixed form networking is better. As I had mentioned before, you can run minimal Cat-5e/6 runs for just those items that are Access Points, Switches, devices that use Wireless-G only. Everything else can be done with Wireless-N & AC.
You are now seeing even Ethernet over Power exceeding 500mbps.
Tags
basement , cable , fish
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 08:15 AM
Running cable to unfinished basement delhux Electrical 5 02-20-2011 02:54 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
CABLE for TV in basement DIY4EVER Electrical 5 06-19-2007 06:01 PM
