Drilling Through Top Plate On Load Bearing Wall - Electrical - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By Nealtw
  • 1 Post By Wiredindallas
  • 1 Post By huesmann
  • 1 Post By Nealtw
  • 1 Post By Mystriss
  • 1 Post By Nealtw
Old 05-28-2019, 09:16 PM   #1
Rewards Points: 22
Drilling through top plate on load bearing wall
Hello,
Could I drill holes through top plate of a load bearing wall (exterior wall)?
I need to relocate/move 7 armored wires through the top plate.
Will this weaken the wall structure? All the wires come though the bottom plate, the electrical panel is located directly below. Please see attached pics.
Thank you for your help in advance!
Drilling through top plate on load bearing wall-img_9993.jpg   Drilling through top plate on load bearing wall-img_9994.jpg
FirstHome_MKE is offline   Reply With Quote
Old 05-28-2019, 09:28 PM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: Drilling through top plate on load bearing wall
Yes you can drill the holes, no it will not weaken the wall.
I would drill 3 holes large enough for 2 cables and one hole for one cable.
The ceiling joist and the roof rafters rest on the top plate which rest on the wall studs below.
That shielded cable will not pull through holes easily. Probably need holes 1 1/4" diameter.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
FirstHome_MKE (05-28-2019)
Old 05-28-2019, 09:33 PM   #3
retired framer
Rewards Points: 15,550
Only be concerned when the joists are landing between the studs, yours are find for holes.
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Old 05-28-2019, 09:55 PM   #4
Rewards Points: 58
Drill in the center to avoid possible wallboard screws/nails reaching the wires.
Wiredindallas is online now   Reply With Quote
The Following User Says Thank You to Wiredindallas For This Useful Post:
Old 05-29-2019, 08:33 AM   #5
Rewards Points: 4,440
Pardon my ignorance, but why not just run them above the top plate and down behind it?
bob22 likes this.
huesmann is online now   Reply With Quote
Old 05-29-2019, 11:07 AM   #6
Rewards Points: 22
If I'm understanding you correctly what you are saying is to cut/drill the black board behind the top plate? My only concern is that is the exterior wall/siding and I did not want to put a hole in it (moisture, water, bugs, rodents).
Old 05-29-2019, 11:10 AM   #7
retired framer
Ignore that, he said it with out thinking it thru.
FirstHome_MKE likes this.
figure 7-14
Old 05-29-2019, 11:22 AM   #8
Mystriss's Avatar
Rewards Points: 7,350
I managed to drag the following consolidated advice out of the internet a few months ago:
Holes in 2x4 double top plates can have a 1 1/4" max hole diameter and the center of the bore can't be more than 1 1/2" from the edge (aka center that sucker,) and you want to space them out at least an inch.
(I think you've got 2x4's there in the pic, I'm not great at estimating sizes though. If they're 2x6 or 2x8 you can check out the thread I posted my list of finding in Here
Nealtw likes this.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is online now   Reply With Quote
Old 05-29-2019, 11:32 AM   #9
retired framer
There are times they put bigger holes for plumbing vents and things, you watch out for the support of members above not being supported and a steel strap across the opening for the lateral push and pull.
Mystriss likes this.
figure 7-14
Old 05-29-2019, 11:57 AM   #10
Mystriss's Avatar
@Nealtw Aye, the 3" main stack/drain pipe is a noted exception for 2x4 construction - just didn't think it was relevant to the OP's question enough to mention
Nealtw likes this.
Old 05-30-2019, 09:38 AM   #11
You're right, and also without blowing up the pic. Now I see there's some kind of felt or something behind the studs, and not just a dark space.
