Downlighting With Least Amount Of Heat? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 12:32 PM   #1
Downlighting with least amount of heat?
I am about to install some downlighting into a living room and was wondering what kind of options do I have for getting the most amount of light but with the least amount of heat. The room will have 8 downlights, and I would rather do the canned types (not wanting to get into $200+ per light).
Fluorescent is not an option because of interference they cause with some audio stuff I will have plugged in.
Are LED the way to go? I see this on Home Depot ( http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 ) but I am unsure if this has to be installed first, or if this works with existing canned light enclosures. It looks like it just screws in like a normal bulb, but converts into an LED.
Thanks for your help!
Swaff
swaff is offline   Reply With Quote
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Bryant/Honeywell T841A 1639 thermostat problem MikeInMobileAL HVAC 0 01-08-2010 07:14 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
