Double Up On Ground Wire? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 07-05-2017, 03:29 PM   #16
Rewards Points: 42
Re: Double up on ground wire?
It is tripping the breaker. Could be a nail or other issue. Whatever the cause, it's behind the wall.
Sent from my SM-G955U using Tapatalk
mga56grg is offline   Reply With Quote
Old 07-06-2017, 03:10 AM   #17
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 2,002
Originally Posted by mga56grg View Post
My question is if I should also pigtail the new ground wire for the disposal in the sink outlet, to the existing ground used for the dishwasher?
Not only should you, you are required to ground the circuit extension you added.
You may use the equipment grounding conductor of the dishwasher circuit to do this as long as all of these requirements are met:
1. Your location is using the 2014 or 2017 NEC.
2. Dishwasher circuit is properly grounded and the grounding conductor is of sufficient size for the circuit you're extending.
3. Dishwasher circuit and extended circuit both originate from the same breaker panel.
4. The extended circuit is protected with an AFCI (or AFCI/GFCI) breaker.
Are you attaching this red conductor to the open screw terminal on the hot side of the existing receptacle? Does the receptacle have the connection tab intact?
J. V. and 47_47 like this.
Fishbulb28 is online now   Reply With Quote
Old 07-06-2017, 06:33 AM   #18
Rewards Points: 18
That last question is a great one! That never occurred to me.
Sent from my LG-D415 using Tapatalk
J. V. likes this.
jeffmattero76 is online now   Reply With Quote
Old 07-06-2017, 01:56 PM   #19
Rewards Points: 42
I put the red on a separate recepticle. I meet 1-4 above, so went with that this am. Disposal done. Thanks guys.
jeffmattero76 likes this.
Securing Ground Wire snahdog Electrical 7 10-10-2014 12:42 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
voltage on ground wire - multiple ground problem? Thaiman Electrical 14 04-02-2011 11:49 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
