Double Feed Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 12:46 PM   #1
Rewards Points: 77
Double feed question.
Hi all, hope you're enjoying your weekend and not trying to fight off the flu like me!
The reason for this post is about a double-feed situation. Here's what happened. During my basement electrical rough-in, I tapped into an existing feed for a new wall and 2 piece bath from an existing circuit which I thought had only 5 devices on it. It turns out it's nearly maxed out as it is, and I would be overloading the circuit. So, I ran a new feed to the wall but to the opposite end. So now it's fed twice.
Is this an issue?
mlijoi is offline   Reply With Quote
Old 01-06-2013, 02:15 PM   #2
Rewards Points: 17,936
Bathrooms need there own 20 amp circut, the circut can not be shared, both light and outlets can be on the same circut.
Outlets need to be GFI.
Old 01-06-2013, 02:21 PM   #3
Engineer
Rewards Points: 161
Is this an issue?
What exactly is "fed twice?" You need to disconnect your first run to the bathroom as the bathroom needs to be a dedicated circuit. By your terminology, and phrasing, it doesn't sound like you're too familiar with electrical and code.
diystephen is offline   Reply With Quote
Old 01-06-2013, 04:32 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Keep in mind the OP is from Canada. I know their bathroom codes are different than NEC codes. A "double feed" can be a very bad thing.
-Turn off the breaker, think the circuit is dead, and it isn't
-BOOM! Circuit is fed from opposite legs.
Old 01-06-2013, 04:34 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 692
The poster is from Canada which has different bath requirements than the NEC.
Disconnect the first feed you installed. Now that was't hard.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-06-2013, 04:49 PM   #6
Rewards Points: 320
In addition to the code issues you cannot feed the circuit twice. Any time you run a new feed to an existing circuit you need to disconnect the original feed.
teamo is offline   Reply With Quote
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Boiler water feed and aquastat question timothy918 HVAC 4 01-29-2011 07:24 PM
Double feed problem jbsayad Electrical 2 06-05-2009 10:25 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
feed back voltage when using double breaker sluggermike Electrical 59 09-20-2007 02:37 PM
