Door Lights: Do They Need Their Own Junction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 02:29 PM   #1
Rewards Points: 151
Door lights: Do they need their own junction box?
I'm replacing my existing door lights (as part of a massive residing project). The lights to the side of the entrance doors to the house and to the side of the garage.
They're all the basic door lantern, except for the front door which is a little bigger.
Previously, they *all* just have a wire hanging out of the house through a small hole which were then just twist-connected onto the wires of the light hidden in its base against the wall.
I was warned though that the "new codes" require that a junction box be recessed into the wall. And THAT is what the light is supposed to be attached to.
Is this true? I cannot find mention of it anywhere, though to be honest, I'm terrible at reading building/electrical/etc. codes. Can I legally & safely just connect those wires in the back in a weather protected fashion and call it a day?
THANKS!!!!
tgm1024 is offline   Reply With Quote
Old 11-20-2010, 03:19 PM   #2
Yes, all 120v+ light fixtures require a junction box. On an exterior light, you can cut a recessed box in or you can use a 4" pancake box. The pancake is thin enuf so you just have to cut into the siding
heartlessmcfly is offline   Reply With Quote
Old 11-21-2010, 10:40 AM   #3
Rewards Points: 308
It depends on the fixture. Boxes are not always required.
Old 11-21-2010, 10:46 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
This is true, but in my experience this is only about .01% Of the time with typical residential fixtures.
Also, this is absolutely NOT a "new" code. Your existing lights were most likely a violation.
Old 11-21-2010, 10:57 AM   #5
Rewards Points: 320
I usually use siding blocks like these......
ttp://www.arlcatalog.com/Siding/siding.pdf
Some of them have a built in box with a cable clamp and eliminate the need to cut in a pancake box.
teamo is offline   Reply With Quote
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Mounting junction boxes in attic, are both of these locations acceptable? diymonkey Electrical 33 04-09-2009 07:24 AM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
