Do I Need Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 09:32 AM   #1
Rewards Points: 91
Do I need conduit
I am going to be running a dedicated 20 amp line from a panel for a washing machine. The run is about 35-40 feet. The wire will be in the attic. Is it "legal" per NEC to just run the Romex? in the attic and staple along the way without using some type of conduit to enclose the wire?
drjay9051 is offline   Reply With Quote
Old 08-30-2010, 09:40 AM   #2
Where are you located ?
In most cases yes you can just use romex
Old 08-30-2010, 09:56 AM   #3
Rewards Points: 91
I'm new to all this. BTW: I assume it's OK to use a 20 amp breaker if I use correct guage wire? Most of the circuits in this older house are 15 amp. I do know I CANNOT install a 20 amp breaker with wire sized for 15 amp.t
Located in Ocala, Fl. Thanks for your help.
Old 08-30-2010, 10:02 AM   #4
Licensed electrician
Rewards Points: 3,662
The laundry circuit needs to be 20 amp by code.
The wire will need to be protected within 6' of the attic scuttle or within 7' if the attic has stairs.
Old 08-30-2010, 10:10 AM   #5
Rewards Points: 91
Scuttle?? So does this mean conduit or not.
Old 08-30-2010, 10:18 AM   #6
Scuttle = access panel.
The protection can come from running boards or a suitable conduit type.
Old 08-30-2010, 10:58 AM   #7
Rewards Points: 91
Thanks, Jim
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
