Do I Need To Bond ....? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 01:03 PM   #1
Do I need to bond ....?
I am installing a new 200 AMP breaker panel on the north side of my 60' x 90' shop. It is a 220 3 phase service with a 200 amp main breaker and wired to the 400 amp main service on the south side of the building. I have pulled the wires (3 legs and the neutral) through existing 2" PVC conduit not EMT. My question is do I need to bond the box and install ground rods?? Thanks for the help!!
Dieseltech is offline   Reply With Quote
Old 01-22-2010, 01:31 PM   #2
Rewards Points: 266
You need to run a ground wire along with your other conductors in the conduit. (3 hots, neutral, and ground) No ground rods. The panel would be set up as a sub panel and have the neutral unbonded.
How big of wires did you run??
junkcollector is offline   Reply With Quote
Old 01-22-2010, 01:43 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I am not as clear as Junk on this one.
You said "main" twice. Where is the service equipment? Basically the main disconnect/breaker.
From where to where? The service to the panel 90' away? Or between the meter and service equipment?
Which "box"?
You ALWAYS need some form of grounding electrode. You also need to bond metallic piping systems (gas, water, etc), building steel, footing/slab rebar, and more. These all terminate in the service equipment.
Are you an electrician? This is a bit much of a job for a "non-pro".
Old 01-22-2010, 02:03 PM   #4
2/0 wire....main twice as our electrician wired this in the main service panel to a 400 amp breaker and then the subpanel just installed has a 200 amp main breaker in it, it is 54 feet exactly from the main service to the new subpanel but 78 feet of wire as it runs up through the roof, everything else piping, etc is grounded per code....our electrician is in the tropics on vacation and kind of left us hanging so I broke out the ugly's book and made a few calls and am kind of winging it but I wasnt clear on this and before turning power on I wanted to get it right....thanks for the help!!
Old 01-22-2010, 11:28 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
id say call the electrician and ask him,that way theres no isues down the road about whos responsible if theres problems
plummen is offline   Reply With Quote
Copper bond epoxy rjniles Plumbing 10 03-19-2017 09:40 PM
Bond strength of mortar??? figs Building & Construction 7 06-06-2009 03:23 PM
iron bed/peel and bond - Paint Question juju Painting 1 03-09-2009 02:42 AM
Bonding (bond wire) & Spa Installation on existing concrete pad crusius2 Electrical 1 11-14-2007 12:00 PM
Concrete block - bond pattern tvoltz Building & Construction 1 06-11-2007 06:36 PM
