Dishwasher Tripping GFCI Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-30-2016, 07:11 PM   #16
dmxtothemax's Avatar
Rewards Points: 7,696
Re: Dishwasher Tripping GFCI outlets
Originally Posted by Mikedks View Post
A couple weeks ago my dishwasher started tripping the GFCI outlet under the sink, using an extension cord, also tripped GFCI outlets next to sink. Brought in appliance repair guys several times, and they replaced control panel, still tripped the circuit. He believes there is nothing wrong with dishwasher. So I ran extension cord from dishwasher to bathroom GFCI outlets, no problems, next I ran to another separate circuit in the house with no problems.
The bottom line is that the dishwasher will blow all GFCI outlets on the one circuit, but works on all other circuits. Am assuming there is a problem with that circuit or one of the outlets.
Anyone have any thoughts?
Thank You
these other circuits are they gfci circuits as well ?
or are they non gfci circuits ?
will it work on any gcfi circuits at all ?
usually if a gfci blows this indicates a small electrical leak to ground,
the unit can still work in this condition, but the danger is higher.
dmxtothemax is offline   Reply With Quote
Old 05-30-2016, 07:50 PM   #17
Rewards Points: 2,716
Originally Posted by newkyqt View Post
Same challenge. LG D/W on its own GFIC breaker circuit, lightly used appliance. 1 yr later GFIC breaker pops. No leakage found, close inspection, pulled unit out for close inspection, no visible issues. Re-installed D/W new GFIC, breaker still pops about 10 minutes into cycle. Using extension cord, plugged into non GFIC circuit, no issues with operation. Moving to non GFIC breaker for D/W circuit for long term fix.
The dishwasher concerned will have a "Calrod" heating element - similar to that used on electric cook-tops.
The insulation inside these "rods" is a type of ceramic material, which can absorb moisture if the seal where the connection is made is not completely air tight. Even a small amount of moisture can provide a "leakage" path to the earthed metal outer casing - which will trip a GFCI.
For this reason, in this country, such heating devices (Stoves, Water Heaters etc.) need not be protected by a RCD or RCBO if they are permanently connected to a dedicated circuit (or via a "non user accessible" socket outlet on a dedicated circuit.)
You said that it was a "lightly used appliance", which makes the ingress of water between uses quite likely.
I suggest that you run the device via a lead from a non GFCI protected outlet temporarily and see if this "dries out" the fault when it is plugged back into its normal outlet.
If it does not then operate without tripping the GFCI, you could either
replace the heating element or
run the device on a non GFCI protected (dedicated ?) circuit.
My choice would be the latter.
FrodoOne is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 11:59 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 08:23 PM
downstream of GFCI outlets amakarevic Electrical 11 12-25-2008 02:13 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
