Dishwasher Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 04:29 PM   #1
Dishwasher outlet
Can someone tell me if you need a 110v or 220v outlet for a dishwasher? Thanks
Not Mechnical is offline   Reply With Quote
Old 06-09-2010, 04:32 PM   #2
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Unless it is a commercial model it is probably 120-volt but you should refer to the specs for the unit you are looking to install!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-09-2010, 05:34 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
There is NO literal correct answer to this vague question.
The common sense answer was made in post #2.
Old 06-09-2010, 08:51 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Try 240, if it smells funny when you turn it on, then try 120.
Actually it's most likely 120, but I'd read the specs. May need a 20 amp circuit, or maybe 15 will do, all depends what the specs say. Most residental will be 15 amp at 120 volts.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
