Discussion On Switch Grounding/bonding - Electrical - Page 7 - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 07:05 PM   #91
Rewards Points: 506
When using NM cable with metal boxes, does the code state the cable must be connected (attached, whichever) to the box (as if with a connector in one of the knockouts)? I looked but couldn't find it. Seems that the same would apply with plastic boxes. [Edit: Yes, with exceptions for non-metallic boxes. 314.17(C)]
This is a stretch from discussing bonding/grounding, but, if a metal NM cable connector is used in a plastic box, does it need to be bonded. If yes, then all the more reason not to used a metal connector with a plastic box.
jlmran is offline   Reply With Quote
Old 03-21-2010, 07:08 PM   #92
Originally Posted by jlmran View Post
A red X
The Following User Says Thank You to Scuba_Dave For This Useful Post:
jlmran (03-21-2010)
Old 03-21-2010, 07:18 PM   #93
Rewards Points: 506
Originally Posted by Scuba_Dave View Post
A red X
Good one, thanks. I edited the post.
Old 03-21-2010, 07:36 PM   #94
The box with clamps most people would use the clamps
The wire must be secured within "x" inches of the box depending upon the circumstances
No requirement to fasten it to the plastic box
A metal box is totally different
They usualy have clamps built in to secure the wire
I don't know anyone that would use a metal clamp on a plastic box
Added expense & not needed
Old 03-21-2010, 09:01 PM   #95
Thumbs up
Originally Posted by brric View Post
There is ASOLUTELY no reason to attach any wire to any plastic box ever.
To the EGC THAT IS ANCHORED AT THE BOX..... (The ultimate symbol of confusion)!
spark plug is offline   Reply With Quote
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
