Discussion On Switch Grounding/bonding - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 09:50 AM   #61
Rewards Points: 506
Residential - bonding to water lines
So, what were the original intentions when the bonding of electrical systems to the water systems began?
1. Using the water pipes as a connection to earth for stabilizing the electrical system?
or
2. Connecting the water system to the 'grounded conductors' of the electrical system so as to prevent injury to a person should the water system become energized with harmful voltage from the electrical system.
Reference post #49.
jlmran is offline   Reply With Quote
Old 03-20-2010, 10:02 AM   #62
Master Electrician
Rewards Points: 5,084
or
Reference post #49.
Connecting to a metallic water pipe that is in contact with the earth for at least 20' establishes part of the grounding electrode system.
Bonding of metallic piping not in contact with the earth such as copper piping coming off of a plastic main is a safety device as you note in #2 above.
The 'grounded conductors' of the system are the neutral conductors as opposed to the 'grounding' conductors.
brric is online now   Reply With Quote
Old 03-20-2010, 10:17 AM   #63
Master Electrician
By the way, the equipotential grid on a pool is contected to pumps, heaters, etc. which are in turn connected to grounding electrode system via the respective equipment grounding conductors.
Old 03-20-2010, 10:21 AM   #64
Rewards Points: 506
I stand corrected...should have used grounding instead of grounded. But, you still didn't answer my question, you only restated it. Are there any NEC historians out there?
Old 03-20-2010, 10:45 AM   #65
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you need to read 680.74. There is no requirement and in fact, there are times where the equipotential grid will not be connected to the equipment grounding conductors.
Any actual connections is purely coincidental and is not required.
Old 03-20-2010, 11:57 AM   #66
Rewards Points: 2,800
Just a guess.
The earth is not that great a conductor of electricity. When a ground rod is installed anyway, it is still possible for everything bonded to it to have a voltage difference relative to everything bonded to the water pipe exiting the house, so bonding the water pipe and the ground rod eliminates that voltage difference.
The problem (of two equipotential grids not necessarily at the same potential, or voltage relative to one another) of course does not exist when the pipe is the (primary) grounding electrode.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 03-20-2010, 02:25 PM   #67
Master Electrician
That only covers hydromassage tubs.
Old 03-20-2010, 02:27 PM   #68
nap
You talking to me?
nap's Avatar
before you even need to deal with that, you need to understand what an equipotential plane is and why it is used.
In very simple terms, it is to establish an area where there will be no difference in potential (voltage) between any two involved conductors. Removing a difference of potential means you will not get shocked regardless of how much voltage (as measured to some other point) is present.
electricity is pretty simple in that matter:
no difference of potential, no current flow.
so, at a pool, in an animal barn, at a cell tower and many other areas utilize an equipotential grid so as to remove the possibility of there ever being a difference of potential between two involved conductors regardless of the source of the voltage.
If you have two or more areas, unless there is a possibility of contacting a point from each of them at the same time, there is no benefit of bonding those two equipotential systems together. It serves no purpose.
that is why a pool equipotential system does not necessarily have to be bonded to the homes GES. While you are at the pool, the only thing you must worry about is getting shocked from is another conductor at the pool area. Only if you can also contact something at the house would the homes GES need to be interconnected.
the earth grounding is not the intent, just the bonding.
and if you want to see a very good yet simple example of why bonding us used, watch this video
High voltage + bonding = no electrocution
Old 03-20-2010, 02:30 PM   #69
nap
You talking to me?
nap's Avatar
yep, you are correct. refer to 680.26. more rules/ same intent
Old 03-20-2010, 02:51 PM   #70
Rewards Points: 506
Nap - I believe your explanation even applies to those things generally not considered conductors. For example, if the voltage and current associated with rubbing your socks on the carpet and then touching a doorknob were to somehow be identified as hazardous, then there probably would exist a construction code which requires the bonding of carpets to doorknobs!
Old 03-20-2010, 03:44 PM   #71
Master Electrician
Please read 680.26(B)(6)(a).
Old 03-20-2010, 03:56 PM   #72
nap
You talking to me?
nap's Avatar
ok
I'm missing your point.
Old 03-20-2010, 03:57 PM   #73
nap
You talking to me?
nap's Avatar
there are places I have been that that would be a welcome addition to the bonding rules
Old 03-20-2010, 04:09 PM   #74
Master Electrician
ok
680.26(B) saya it does not have to go back to a panel,service equipment, or electrodes. It does not say it isn't supposed to be connected the grounding electrode system.
680.26(B)(6)(a) says that it must be connected to the grounding electrode system by connection to the equipment grounding conductor of the pump motor circuit.
Old 03-20-2010, 04:29 PM   #75
nap
You talking to me?
nap's Avatar
only under certain circumstances plus it speaks ONLY to a double insulated pump motor and did you catch the part about a replacement motor?
I never said it couldn't be. I said it is not required to be unless other reasons require it.
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
