Discussion On Switch Grounding/bonding - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 10:02 PM   #16
Rewards Points: 506
Originally Posted by spark plug View Post
I agree with you 100%. But, assuming the work is left to experts. The rest IS semantics. (One of my hobbies, as you can see in my profile.)!
Etymology...awesome.
jlmran is offline   Reply With Quote
Old 03-16-2010, 10:05 PM   #17
Rewards Points: 506
Originally Posted by nap View Post
NO NO NO
it is attached to the equipment grounding conductor. the EGC is the term the NEC uses and we should not attempt to alter that.
Again...this assumes the NEC uses correct terminology.
Old 03-16-2010, 10:09 PM   #18
Rewards Points: 506
What happened? I think a moderator started a new discussion thread. Is this common and usual? My apologies if we drifted off target from the original conversation.
Old 03-16-2010, 10:15 PM   #19
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
since we are required to abide by the NEC, it matters not if you believe they use the correct terminology or not, it is the terminology that is customary and accepted and the terminology used in the NEC.
Old 03-16-2010, 10:24 PM   #20
Just call me Andrew
Rewards Points: 1,032
I think you just set the world record for most uses of the word "terminology" in one sentence.
I agree, by the way.
Andrew
secutanudu is offline   Reply With Quote
Old 03-16-2010, 10:27 PM   #21
Rewards Points: 506
Sadly, its not a matter of belief, its a matter of fact. In branch circuits, the bare or green conductor physically bond the equipment to the 'neutral' bus bar at the main service panel. That is their sole and intended purpose, no matter what they are called.
Old 03-16-2010, 10:33 PM   #22
nap
You talking to me?
nap's Avatar
then quit worrying about what they are called and call them what everybody else calls them so everybody knows what is being talked about.
and actually, no, that is not their only intended purpose. They are grounded for a reason as well.
Old 03-16-2010, 11:08 PM   #23
Rewards Points: 506
Guess its a flaw I have...can't call something its not. And yes, the green/bare conductors in branch circuits are ultimately connected to the earth, but their purpose is not to connect equipment to earth, their purpose is to connect equipment to the source of the electricity.
I'm tired...Good night, Nap.
Old 03-16-2010, 11:14 PM   #24
nap
You talking to me?
nap's Avatar
they also are connected to ground (earth) for a reason. It is not just by chance they are connected to earth ground. There absolutely is a reason for it and you not realizing it just shows you do not know quite as much as you think you do.
Old 03-17-2010, 12:41 AM   #25
Learning by Doing
Leah Frances's Avatar
Ok fellows - fears realized. Cause I now have no freakin idea how or why what is what. Sigh. I guess this is why I can say that I can install electrical work to code, but I am NO electrician.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-17-2010, 07:44 AM   #26
Another thing to consider is that the U.S. is not the only country in the world. And the Internet as well as this forum can be used by anyone anywhere...
...and other countries use the terms "Earth" and "Earthing"...
http://en.wikipedia.org/wiki/Earthing_system
IEC...
http://en.wikipedia.org/wiki/Interna...cal_Commission
Billy_Bob is offline   Reply With Quote
Old 03-17-2010, 11:31 AM   #27
Thumbs up
This assumes that the NEC is written using correct terminology. I agree...it is semantical.
Yes. As a matter of fact, the NEC makes a distinction between GROUNDED and GROUNDING (when referring to conductors.) (I'm putting a serious face , because it is so (in the NEC)! Also, the ultimate symbol of confusion!
spark plug is offline   Reply With Quote
Old 03-17-2010, 11:49 AM   #28
Thumbs up
IEC...
Yes. Britain and Australia. I can cite more examples of using the same terms with different meaning. But this is a DIY forum and not a Language forum. But the NEC rules in the USA and nowhere else. Conversely, There's a movement (an effort ) to make a universal Electrical Code rule in the USA. But some major (I will not cal them Powerful) organizations, like NECA (National Electrical Contractors Association) are in the forefront of resisting the effort.!
Old 03-17-2010, 12:02 PM   #29
Thumbs up
NO NO NO
Exactly my point. That's why I suggested the work be left to experts. They will use the right terminology and will not confuse "Grounding" with "Bonding".
Old 03-17-2010, 04:51 PM   #30
nap
You talking to me?
nap's Avatar
the thing is, it isn't that jlmran is truly wrong. It's just that he wants to change terminology that has been utilized and accepted the way it is for many years.
what word or name is used is really irrelevant as long as all those involved understand what the term refers to. The wire still does the same thin regardless what you call it.
especially since this is a DIY site, I just believe if he wants to go and try to change the terminology, he is simply going to confuse people that have heard the correct term elsewhere and then when they come and hear him, they may be told the exact same thing but by using different terms, they won't realize that.
electrical work has enough inherent hazards. There is no need to intentionally confuse anybody.
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
