Disconnect A Phone Jack In An Inaccessible Room - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 02:29 PM   #1
Question
Disconnect a phone jack in an inaccessible room
What would you recommend as the best way of disconnecting a jack in the wall of a room that is inaccessible? The rest of the jacks in the house must remain functional.
What is the best way to find the necessary wire to cut off, and where is it likely to be?
Querious is offline   Reply With Quote
Old 10-07-2010, 03:03 PM   #2
Licensed electrician
Rewards Points: 3,658
I don't know why you would want to put yoursself in the middle of a landlord tenant dispute.
Old 10-07-2010, 03:25 PM   #3
Do work
Rewards Points: 81
This would depend if the phones lines are daisy chained together or all home runs. If they are daisy chained then find the jack before and after the one you cant get to. Disconnect both sides then run a wire between the jack before and after. So what was A----->B---->C becomes A---->C.
If they are home runs, then tone out the known lines and disconnect the unknown ones.
liquidvw is offline   Reply With Quote
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 09:00 PM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 General DIY Discussions 2 06-17-2009 04:56 PM
DIY phone junction box for cable telephone service eastie Electrical 5 06-17-2009 07:45 AM
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 08:05 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-17-2007 11:46 PM
