Direct Bus Vs Breaker For Surge Protector - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By avspinball
Old 12-08-2019, 11:56 AM   #1
Rewards Points: 14
Direct Bus vs Breaker for Surge protector
Just bought a HEPD80 for a sub panel that is for lighting. The instructions offer two ways to mount, Direct Bus or with a breaker but it doesn't give any pros or cons with either way. My research has found tons of posts about breaker location closest to the supply and lack of breaker space. But with direct bus it seems to me to make all that moot and easier to install. I haven't found one post about direct bus.
Any insight would be appreciated.
avspinball is offline   Reply With Quote
Old 12-08-2019, 12:41 PM   #2
Oso954's Avatar
Rewards Points: 1,362
Re: Direct Bus vs Breaker for Surge protector
Direct buss connection means killing the main breaker anytime you work on it or replace it. With a breaker, you only have to kill the one breaker. (You wonít have to reset clocks or other electronic settings)
Oso954 is online now   Reply With Quote
Old 12-08-2019, 12:47 PM   #3
Rewards Points: 14
It's a sub panel so it's on a 100 amp breaker in the main so no big deal there. I guess my concern is the HEPD80's wires are 12 gauge, wouldn't they be underrated for 100 amp direct?
Old 12-08-2019, 01:15 PM   #4
Oso954's Avatar
Itís not a problem, surges are very short duration. The wires wonít heat up to a problem point in a couple of cycles.
When you put it on a breaker, SQ D recommends a 20 or 30 amp 2 pole breaker. The breaker isnít there to protect the surge protector. It isnít supposed to trip during the surge. Itís more of a disconnect and easy connection to the bus.
Old 12-08-2019, 01:49 PM   #5
Rewards Points: 14
Thanks.
Makes sense, so does using a breaker. I have spares here so putting a 20 on is no big deal and the better way to go.
Oso954 likes this.
Tags
direct bus , hepd80 , surge protector
