Dimming Lights When Vacuum Is On - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 01:36 PM   #1
dimming lights when vacuum is on
why would my lights in the basement dim when the vacuum is being ran on the 1st floor??
EdAUlrich is offline   Reply With Quote
Old 06-04-2010, 01:57 PM   #2
Except during startup, more than a 3v drop in the basement voltage may indicate a bad connection upstream of both the basement and the vacuum's outlet. If other lights get brighter it's a bad neutral connection.
I opened your link but I didn't find your post.
There is an MDShunk on the site you cited. You wouldn't know if he is the same MDShunk that sued his high school for the right to pass out Creationism literature, would you?
Old 06-04-2010, 03:01 PM   #3
Master Electrician
Rewards Points: 5,082
Is it a central vacuum system?
brric is offline   Reply With Quote
Old 06-04-2010, 10:37 PM   #4
My guess is that your basement lights are on the same circuit as the plug you're using upstairs, to say it simply. When you turn your vacuum on, the motor takes a lot of juice to get going, and that drains the power on your lights which are downstream in the circuit.
altow90 is offline   Reply With Quote
Old 06-05-2010, 12:52 AM   #5
" Euro " electrician
frenchelectrican's Avatar
If dimmed breifly during the vaccum start up it is normal but stay dimmed during running mode then no you have issue you may have loose connection somewhere along the circuit.
Most vaccum I know they will draw about 7 to 12 amp range depending on how big and fancy it is.
with 15 amp circuit it pretty close to trip the breaker if it only load but if you have other loads on that circuit then yeah it will be matter of time before the breaker trip.
Merci,Marc
Old 06-05-2010, 06:50 PM   #6
yea i have no idea what size breaker it is hooked up to but im pretty sure its a 15 amp breaker
Lights dimming randomly in my house HomeRepairNoob Electrical 26 11-02-2010 08:58 PM
House lights dimming Tluther Electrical 7 04-20-2010 09:12 PM
Lights Dimming gpurves Electrical 4 04-05-2010 10:24 AM
Dimming 12V lights jerseyguy Electrical 2 10-23-2009 01:51 PM
lights dimming when using the vacuum farmerde Electrical 21 12-08-2008 08:09 AM
