Dimmer/timer For Low Voltage Led Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2014, 12:41 AM   #1
Dimmer/timer for low voltage led lights
We're planning to install led lighting in vented vinyl soffits around the exterior of the house. We want 6 lights on the rear of the house which are controlled by an indoor dimmer switch and a timer. On the front of the house we want six more lights on a separate dimmer switch and a timer. I've started looking and am interested in low voltage, clip in led fixtures (such as AspectLED and Delphitech) which seem to offer easy installation. Do I need separate power supplies/drivers for the front and back to make this work? I'm unsure of the equipment needed to incorporate a dimmer and timer. Thank you for any recommendations.
shedman is offline   Reply With Quote
Old 09-22-2014, 06:34 AM   #2
dmxtothemax's Avatar
Rewards Points: 7,822
Seperate circuits need seperate supplies
If the drivers are dimer compatible
You can use standard domestic type dimers
And timers.
dmxtothemax is offline   Reply With Quote
Old 09-22-2014, 08:05 AM   #3
Rewards Points: 1,306
You might need special dimmer depending on lamp or power supply. If it's a transformer (magnetic) feeding lower voltage bulbs you need one type. If it's line voltage led bulbs it's another type. Sometimes old fashioned dimmers work on dimmable line voltage LEDs but dimming range and drop out can be a pain. Bulb mfgs usually list many dimmers that work well with their bulb.
Short answer get a dimmer suited for this.
curiousB is offline   Reply With Quote
Tags
dimmer , led , soffit , timer
Replacing existing recessed soffit lights miamicuse Electrical 35 06-22-2013 07:52 AM
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
low voltage wire repair on lights outside kirkaldy Electrical 2 06-04-2012 06:40 AM
Lights got dim, low voltage? menton1 Electrical 3 09-04-2011 07:32 AM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
