Dimmer Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2015, 08:43 AM   #1
Rewards Points: 1,254
dimmer issues
yesterday i put a dimmer and led bulbs, 2, in my garage for the outside lights.
the dimmer will not dim down as low as i want. and at different positions, the lights will flicker. i hope you guys an help me fix this. thanx.
feit 6w dimmable a19 led
GE 18053 dimmer switch.
Fix'n it is offline   Reply With Quote
Old 10-17-2015, 09:14 AM   #2
Civil Engineer
Rewards Points: 5,246
Not all LED's are dimmable, and not all dimmers work with LED's. You need to read the manufacturer's specs for both the dimmer and LED's you used to make sure they are compatible. You may need to change the LED's and/or the dimmer.
Old 10-17-2015, 09:46 AM   #3
the packagings says they are compatable. but perhaps the bulbs are crap, and/or the dimmer is crap. idk.
Old 10-17-2015, 05:55 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,854
If both the lamp and the dimer are lamp are compatable ?
Then it is probably more to do with the quality of both.
But even the best quality ones will exhibit
Similair characteristics but to a lesser extent.
dmxtothemax is offline   Reply With Quote
Old 10-17-2015, 10:34 PM   #5
Rewards Points: 1,428
That is how self-ballasted LED lamps dim.
Different combinations of lamp and dimmer will create different effects, but usually they flicker when dimmed and do not dim all the way.
This is because the dimmer chops up the wave, but the LED lamp has its own electronics, so the chopped up wave does not work well with the LED lamp. Although the LED lamp is designed to work with it so it does not go crazy, it never works very well.
If you want dimmable LEDs you should have a variable low voltage DC power supply in the wall and connected to a low voltage light in the ceiling. With that you can dim it as far as you want and it will not flicker.
poiihy is offline   Reply With Quote
Old 10-18-2015, 01:23 AM   #6
Rewards Points: 234
As others have stated you likely need a different dimmer. I have a candelabra light fixture with 6 candelabra bulbs. I replaced some of the bulbs with dimmable LEDs which it worked fine as long as at least one incandescent bulb remained in the fixture. Take out the final incandescent bulb and it no longer works.
I think the reason is needing some small vampire load to make the old style dimmer switch work.
Edit: Read again and understand that you are using a dimmer switch which claims to work with dimmable CFL/LEDs. I would be inclined to return the dimmer before I questioned the bulb.
RustNeverSleeps is offline   Reply With Quote
Old 10-18-2015, 01:24 AM   #7
Yes, conventional dimmers require a minimum load to operate.
Old 10-18-2015, 07:07 AM   #8
i have dimmed LED's in my kitchen, they work great.
last night i was mess'n with the garage lights. i think its the switch. i am going to change it out for a hopefully better one and see what happens.
Old 10-31-2015, 05:58 AM   #9
i put a lutron dimmer on it. works well now. though i would like it to dimm down a little lower.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
3-way Switch Used to Bybass Dimmer Perry401 Electrical 3 05-14-2014 02:20 PM
Cannot Get New Dimmer Switch Working Correctly BzowK Electrical 8 02-11-2012 04:13 PM
4 way dimmer jamiedolan Electrical 7 08-24-2010 12:45 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
