Dimmer Dangers? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 09:41 AM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Interesting, are those fins special, or do they just act as heat sinks? So if you remove then it can't disapate heat fast enough and hence the lower rating?
Old 06-04-2010, 11:14 AM   #17
Rewards Points: 506
Originally Posted by Scuba_Dave View Post
What Metal Halide lights are low energy use ?
mabe I should add - for thier light output.
forresth is offline   Reply With Quote
Old 06-05-2010, 02:20 AM   #18
Union Electrician
goose134's Avatar
correct.
goose134 is offline   Reply With Quote
Old 06-05-2010, 02:42 AM   #19
" Euro " electrician
frenchelectrican's Avatar
There is the other tricks I done pretty often with dimmers I put the metal switch plates on due they will act like heat sink as well that help a bit with dimmers.
Now to the OP I know you mention pet sanctuary area so there one thing I will mention to you no open luminares { aka bare bulbs } and double check the CFL bulbs to make sure they work with dimmer and also with enclosed luminaires as well.
Merci,Marc
The Wife said, "The lights are flickering." Dimmer on aluminum wiring Law911 Electrical 4 03-26-2010 11:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
