Detatched Structure - 100 Amp + 3way - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2009, 09:07 PM   #1
Rewards Points: 502
Detatched Structure - 100 amp + 3way
I am running 100 amp service to my workshop, which is about 180' from the main panel in the house.
I also want to setup two 3-way switches between the house and barn.
One switch will control a light on the front of the barn, the second switch a light on a pole between the house and barn.
Does it matter which structure "feeds" the 3-way switches? Is this even allowed?
(I will be running the 2-2-2-6 wire and several runs of 14 THHNW-2 for the 3-ways all in the same 1 1/2" conduit.) The conduit terminates directly into the main panel of the house and the sub-panel in the barn. From there I will split the 14 gauge to the switches and lights they will control.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 08-11-2009, 09:10 PM   #2
Electrical Contractor
kbsparky's Avatar
I would feed them from the barn panel, so that if you switched off the feeder breaker, then all the wires in that conduit would go "dead"
-KB
Old 08-11-2009, 09:20 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
A 3 way switch set up allows you to control a light or lights from two locations but you cannot separately control two different lights...one from one switch and one from the other. Maybe I'm not understanding correctly.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-11-2009, 09:22 PM   #4
Rewards Points: 502
Thanks. I was thinking along the line of feeding them from the barn. An inspector shouldnt care that I run 12 or 14 THHNW (or whatever it is called) in the same conduit run, right? My plan was to do a splice in the panel to romex cable.
-Andrew
DIY hobbiest
Old 08-11-2009, 10:15 PM   #5
Rewards Points: 502
I should have said one set of switches will control barn light, the second set . . .
-Andrew
DIY hobbiest
Old 08-12-2009, 12:07 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Yeah I sorta felt like that is what you wanted. Just didn't want you pulling wire then find out you goofed.
Stubbie
Old 08-12-2009, 11:51 AM   #7
J. V.'s Avatar
Rewards Points: 370
I would use #12. And yes, you can run the switch loop inside the same conduit as the feeder. Use THHN/THWN for both. It's a wet location.
Need help building this structure bluefitness Building & Construction 9 03-27-2010 10:28 AM
Wire Dimmer And A 3way On The Same Circuit CTOBINMYERS Electrical 3 11-17-2008 07:28 PM
3way switch satsu Electrical 18 09-08-2007 09:28 AM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
