Detatched Garage Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 10:53 AM   #1
Rewards Points: 74
detatched garage sub panel
A friend asked me to help him install a sub panel in his garage. I installed one in my garage about a year ago so I know how to do it but need some help on wire sizing. He has a 100 amp panel in his house and would like a 60 amp in the garage, is there any problem with this? It's probably a 60-70 ft run. What size wire would I need for this? Is 6 gauge good or would I have to use 4 gauge(copper) due to length of wire? Also what size would I need if I end up using aluminum, if it's cheaper? Also what is the most cost effective type of wire to run? Is it usually cheaper to use conduit and wire or just use direct burial wire? Thanks for your advise on this
ponch37300 is offline   Reply With Quote
Old 08-02-2009, 11:23 AM   #2
#6 copper wire is fine for 60a sub panel
(2) #6 black hots
(1) #6 white - not remarked
(1) ground - I used #8 for mine
Grounding rod(s) will be required for detached structure
What does he have for electric use in the house?
Has a total load calc been done for the whole house?
I prefer buried in conduit - easier to change wire of anything ever happens
Max 360 degree of bends between pull points
I prefer not to use Alum
Old 08-02-2009, 11:40 AM   #3
Rewards Points: 74
He has a 100 amp panel in the house. How is a whole house load calculation done? Thanks.
Old 08-03-2009, 05:02 PM   #4
Rewards Points: 74
Can anyone tell me how to figure out the total load calculation?
Also is it alright to put a 60 amp breaker/subpanel off a 100 amp panel?
For a 60-70 ft run 6 gauge copper is alright, and what gauge aluminum?
Old 08-03-2009, 05:22 PM   #5
I had a nice link to an Excel spreadsheet, but can't find it
Whole house load calc:
http://ecmweb.com/mag/electric_dwell...feederservice/
http://www.selfhelpandmore.com/home-...ation-2002.php
Well - this isn't the excel spreadsheet I used:
http://www.mikeholt.com/documents/ca...lculations.xls
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
rewiring garage - adding sub panel wombosi Electrical 3 05-28-2009 10:08 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Detached Garage Sub Panel MainePainter Electrical 6 08-25-2006 09:58 AM
