Dead Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 10:09 PM   #1
dead plug
have a two plug outside elctical outlet, worked at holloween, can't get Christmas decorations to work, dead plug. Tried breaker box, all right...........hmmm?
dinosaur863 is offline   Reply With Quote
Old 11-30-2010, 10:12 PM   #2
Electrician
Flip all of your breakers to the OFF position and then back ON. It's good to exercise them once a year anyway. Check for any GFCI breaker, if you find one, press the RESET button. If this doesn't help, go looking around your basement, then garage, then first floor bathroom for a GFCI receptacle. Any time you see one, press the TEST button and then press the RESET button.
Hopefully this will fix your issue.
VersaBar is offline   Reply With Quote
Old 11-30-2010, 10:20 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,716
that question reminds me of the Christmas Vacaton movie where the receptacle was turned off by a wall switch and many hours and many mishaps later they discover the switch, great stuff, very funny movie
hardwareman is offline   Reply With Quote
Old 12-01-2010, 11:25 AM   #4
Rewards Points: 308
That was a funny movie. But I put my money the GFCI receptacle is tripped.
Old 12-07-2010, 01:19 PM   #5
dead plug
Grrrrrrrrrrr, lol* nope did not work...............crazy because the two plugs are outside, we had Haloween pumpkin pluged in and it worked, now we get set to do the Christmas stuff, they don't work..........rats
Old 12-07-2010, 01:44 PM   #6
the Musigician
DangerMouse's Avatar
Are you sure it's the outlets? Have you tried a 'known to be working' lamp/tool or something similar?
DM
Old 12-07-2010, 01:59 PM   #7
outlets.........
Pretty sure, first thing I did (and several times since) was to plug in small desk lamp to both sockets, they are covered like all outside plugs........did all the re-set suggestions and breakers..........still doesn't work..........is it possible all the 'magic' just wore out? lol*........even called former owner.............he said sohuld be working fine, never had proble.........?
Old 12-07-2010, 02:19 PM   #8
the Musigician
Next step if it were me would be cut the breaker, pull the outlet and inspect.
It might be one of those stupid "backstabbed" outlets and the wire(s) just came off!
DM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 06:44 AM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 09:03 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
