Dead Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 10:50 AM   #1
Dead Outlet
Hi I recently bought a house in South Florida and came across a dead outlet in bedroom. I checked all breakers and gfci's, opened outlet and checked wiring. No power in wires to outlet. I removed nearest outlets in room to check for disconnected wiring but couldnt find any problems. How do I figure out where problem exists?
shark18020 is offline   Reply With Quote
Old 01-22-2010, 10:50 AM   #2
Licensed Pro
Check for a switch that may control the receptacle.
Old 01-22-2010, 10:52 AM   #3
Old 01-22-2010, 10:53 AM   #4
no switch controlling recept
Old 01-22-2010, 10:56 AM   #5
pic of outlet with wires please
Old 01-22-2010, 11:05 AM   #6
Will get pic as soon as possible Sorry Didnt think of taking a pic (right now room is used for storage and has a heavy desk in front of outlet)
Old 01-22-2010, 11:08 AM   #7
how many wires in nonworkig outlet box
Old 01-22-2010, 11:10 AM   #8
there are two wires
Old 01-22-2010, 12:00 PM   #9
Super Moderator
joed's Avatar
Rewards Points: 24,048
I also think it is a switch issue. If you are certain it is not then go to the working receptacle nearest and check it for loose connections.
Old 01-22-2010, 12:13 PM   #10
I don't know what kind of access you have to wires and stud bays, but how easy would it be to simply run a new wire from another working outlet? It may be easier than finding (then fixing) the fault. You could spend hours poking around in adjacent boxes and in understanding your house circuits trying to figure this one out.
Make sure you cap off your old wires if you take my suggestion.
oberkc is offline   Reply With Quote
Old 01-22-2010, 03:21 PM   #11
Dead Outlet
Hey All Thanks for your input. I have checked switches, gfci's, breakers and nearest working outlets but could not find any capped, disconnected or broken wires. Because of its placement in the room it is a necessary outlet . So before I run new wires or cut a whole in the wall I thought there may be some kind of signal (or wire) tracer that can identify where the wiring terminates in the wall with some kind of input into the plug? Does this exist?
Old 01-22-2010, 03:26 PM   #12
Yes, they exist. I don't think they work well with non-energized wiring, however. Perhaps you could rig some sort of jumper from a power supply (another wall outlet?) and energize the dead wire, then trace it, but this sounds like a little more effort and risk than I would be willing to take. I guess it all depends how much work it would be to run a new wire.
Old 01-22-2010, 11:24 PM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
check plugs on either side to see where its fed from
plummen is offline   Reply With Quote
Old 01-23-2010, 07:14 AM   #14
Just call me Andrew
Rewards Points: 1,032
You could try replacing the outlet first - would rule that out, and outlets are cheap.
Andrew
secutanudu is offline   Reply With Quote
Old 01-23-2010, 08:34 AM   #15
Originally Posted by shark18020 View Post
there are two wires
is there a ground wire, bare copper, is it a plastic box?
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet is dead but ears are hot!? Whassup? Hubandwif Electrical 33 03-23-2009 08:01 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
