DC Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2018, 01:09 PM   #1
Rewards Points: 2
DC questions
Hello all,
I'm new to the site and wanted to know if anyone has ever had to "Hot Wire" a Lazy Boy Lift Chair before. All the AC power to the chair was chewed up by a dog. I have the AC/DC power supply, The lift ram with a limit switch on it, the motor(gear box), and the actual hand pendant with two buttons for up and down.
Here is a quick run down-
Motor has Blue and Black wires
Ram has Blue and Yellow for the limit switch (Full stroke)
AC/DC Power Supply has Blue and Brown
The Hand Pendant has two buttons. One is UP and I get ohms from Grey to Green and Down I get ohms from Grey to yellow
I know the Ram and motor were wired so that the Motor(Black) and Ram(Yellow) were together, so both power lines to the motor action were blue.
I think buying a RTC switch would be easier than trying to use the hand pendant.
If anyone wants to try to help me, I will keep checking the feed.
Thank you,
David Neau
DrNeau is offline   Reply With Quote
Old 12-25-2018, 12:32 PM   #2
Rewards Points: 1,306
DC questions
Was it just the AC cord before the power supply that was damaged? Were all the DC wires to motor and control pendant ok?
If so I wouldn’t make this job any bigger than needed. Go buy an extension cord of same wire gauge, plug style, and cable jacket style and replace the chewed cord.
curiousB is offline   Reply With Quote
Old 12-25-2018, 11:51 PM   #3
Rewards Points: 304
Re: DC questions
Pictures of power supply?
Black square box plugs into wall or is power supply inside chair?
slipparee is offline   Reply With Quote
Tags
ac/dc adapter , switches
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
Mobile Home Carpentry questions immeraufdemhund Carpentry 3 11-19-2010 06:52 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-24-2010 11:53 PM
A few roof questions before I begin... chrisexv6 Roofing/Siding 6 05-02-2010 06:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
