Dc Charger Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 12:42 PM   #1
dc charger wiring
I am replacing the plug on a 12v dc cord for a car heating pad. How can I tell which wire is + and which is - ? One has writing on it, and the other a series of dashes no + anywhere.
kmckiwi is offline   Reply With Quote
Old 08-14-2010, 02:24 PM   #2
Electrician
Proby's Avatar
Do you have the original plug? Open it up and see which wire is connected to the center pin of the plug (positive) and which wire is connected to the outside sleeve (negative). That's the way to be sure.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
kmckiwi (08-14-2010)
Old 08-14-2010, 02:30 PM   #3
Unfortunately, I think i cut it off too short, but I will open it up, and see if there is enough inside to tell. THANKS!
Old 08-14-2010, 03:10 PM   #4
Electrician
Proby's Avatar
If not, I would assume that the wiring is positive and the dashes is negative. But I always like to check to be sure.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
