Cutler-hammer 30 Amp 2-pole Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 09:01 AM   #1
cutler-hammer 30 amp 2-pole breaker
How does this attach to the panel box ?
White1944 is offline   Reply With Quote
Old 12-22-2010, 09:24 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,532
Ayuh,... If you've got the Right breaker for the Right box,...
They just Snap in...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
White1944 (12-22-2010)
Old 12-22-2010, 11:16 AM   #3
Thanks, both the box and breaker are Cutler-Hammer. Its snapped in and now I'm ready to attach the wires. The power is off.
The wire from the generator has three strands......black, red and green.. Which two attach to the breaker ?
Old 12-22-2010, 11:30 AM   #4
Rewards Points: 330
red and black go to breaker...IF YOU ARE TRYING TO USE THIS SET-UP TO POWER YOUR HOUSE DON'T.YOU WILL NEED 4 WIRES.WHITE,RED,BLACK,GREEN.ALSO IF YOU DON'T KNOW WHICH WIRES GO WHERE,GET SOME PROFESIONAL HELP BEFORE YOU GET HURT...
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
Old 12-22-2010, 11:36 AM   #5
Experienced
Jackofall1's Avatar
Rewards Points: 2,102
I would be more worried about the guys working to repair the service, cause it certainly sounds like White1944 is trying to backfeed his service with a gen, with out an auto switch.
Old 12-22-2010, 11:50 AM   #6
Lightbulb
Old 12-22-2010, 11:57 AM   #7
I have Cutler-Hammer panel box in my garage which feeds from my house. It runs 120 volts to the garage. I recently bought a 5000 watt generator for emergency power outings. I'm hoping to install the 30 amp 2 pole breaker in the garage and hook up the generator to give my house some power during an outage.
Old 12-22-2010, 12:11 PM   #8
Rewards Points: 262
Aside from the aforementioned advice that your generator lead does not have enough wires to tie-into your house wiring, you cannot simply tie a generator into a service or sub-panel via a double-breaker. First of all, a 5,000-watt generator will not be able to provide power to your entire home during a power outage. You need to select which circuits will be powered by the generator (a few lights, refrigerator/freezer, that sort of thing) and make sure the draw of those circuits does not exceed the capacity of your gen.
Second, you must use a transfer switch. This functions by isolating your selected circuits and switching the incoming power to your selected circuits between grid power and the gen. You cannot have any circuit connected to both sources simultaneously. Without the transfer switch, there is potential to backfeed electricity into the power grid and injure or kill unsuspecting workers. That could result in criminal liability if this is the result of an illegal installation.
You'll need to have this work permitted and inspected (your local code may not even permit a a homeowner to complete this work, due to the potential for backfeed to the grid). If you are coming here asking questions about how to stab a breaker into your panel, this is out of your league. Call an electrician.
clashley is offline   Reply With Quote
Old 12-22-2010, 12:25 PM   #9
Experienced
Jackofall1's Avatar
Clashley x 10 Especially the last paragraph.
Asking how to mount a CB is the first clue you shouldn't be doing what you are doing.
The Following User Says Thank You to Jackofall1 For This Useful Post:
Speedy Petey (12-22-2010)
Old 12-22-2010, 01:27 PM   #10
Just call me Andrew
Rewards Points: 1,032
You are not just endangering yourself by installing a generator incorrectly, you are also putting utility workers at risk. Call an electrician.
Andrew
secutanudu is offline   Reply With Quote
Old 12-22-2010, 03:19 PM   #11
I thank all my expert electrical friends for their sage advice. You will not see my charred remains at the morgue, nor any utility workers or household members put at risk. A certified electrician is coming tomorrow and I'll pay him with my Christmas booze money. Merry Christmas all!!!!
The Following 2 Users Say Thank You to White1944 For This Useful Post:
secutanudu (12-23-2010), Speedy Petey (12-22-2010)
Old 12-22-2010, 03:44 PM   #12
Experienced
Jackofall1's Avatar
Another story with a happy ending, or almost, sorry bout the booze money and Merry Christmas.
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
Cutler hammer tandem breakers Elear Electrical 3 06-16-2010 10:18 PM
wiring two pole breaker ugabulldog Electrical 18 05-24-2010 03:54 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 05:15 AM
2 pole breaker Unregistered Electrical 3 09-11-2004 11:15 AM
