Curious Why They Attached Ground Wire To Faceplate - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 02-13-2020, 10:21 AM   #1
Rewards Points: 88
Curious why they attached ground wire to faceplate
I'm a novice and I'm trying to install a strip vanity light.
I have to get on a ladder and reach over the vanity and there's only room for one person. The faceplate is attached to the back plate by the ground wire which makes it impossible (in my opinion) to hang the back plate unless I let the faceplate dangle and maybe damage the ground wire.
So what was a simple thing is now complicated...for me...at least.
Sorry the image is sideways for some reason.
Thanks,
Cheryl
hayley3 is offline   Reply With Quote
Old 02-13-2020, 11:02 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 794
Re: Curious why they attached ground wire to faceplate
Not uncommon....just support the face plate somehow...tape it to the wall...or a couple of nails to temp hold it.... or cut the ground and just wire nut it back together when you install the top plate.......
MTN REMODEL LLC is offline   Reply With Quote
Old 02-13-2020, 11:15 AM   #3
Rewards Points: 88
I thought the ground wires simply needed to be connected to the wire inside the wall...just didn't make since that it is connected to the faceplate also..
Good idea on nailing it up..too heavy for tape.
Old 02-13-2020, 11:21 AM   #4
Rewards Points: 794
That ground wire just insures the metal face plate is grounded also in case of a ground fault......(probably is anyway by nature of the screws that attach the faceplate to the wall plate, but paint can interfere with that continuity so they insure it has a good ground.....I often let it just dangle carefully....never had it break.)
Old 02-13-2020, 11:23 AM   #5
J. V.'s Avatar
Rewards Points: 332
I use the bare ground to hold it up while I make up the rest of the connections.
That bare wire is very strong. Try to pull it off.
On second thought, don't try to pull it off........lol
China does not care about strength, looks or usability. Fast buck only.
rjniles likes this.
If it worked before you worked on it. You did something wrong.
Old 02-13-2020, 01:21 PM   #6
Rewards Points: 7,603
That face plate is attached to the back plate by a single green screw hiding under the white wire. Simply disconnect for a bit or better yet put it inside a paper bag and let it dangle.
The paper bag is to protect your mirror or wall. The wire can support the weight.
edit: because the painted metal surface might prevent the face from being grounded and it must be in a damp location.
hayley3 likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-13-2020, 02:42 PM   #7
Rewards Points: 88
Thank you ALL so much! I got the light up. You really can't remove the ground wire...that I could see anyway.
I had bigger issues when I removed the other backplate.
There was no hole to shove the wires into the wall. So I had to use my mostly broken oscillating saw to cut through some of the drywall...I hit some kind of box in there but managed to make a bit of a hole.
I took a pic of the ground wire attached to the faceplate and the groundwire attached to the backplate just so you could see it. They look permanently attached to me.
Anyway light is up...whew!!
Curious why they attached ground wire to faceplate-ground-wire-1-vanity-strip.jpg   Curious why they attached ground wire to faceplate-ground-wire-2-vanity-strip.jpg
Old 02-13-2020, 02:58 PM   #8
surferdude2's Avatar
Rewards Points: 1,060
I'd say you have bigger issues! You are required to have an approved junction box to connect a fixture to, not just cut a hole and stuff the open wires and connectors into the wall. That's a fire hazard that you need to correct.
surferdude2 is offline   Reply With Quote
Old 02-13-2020, 03:39 PM   #9
Rewards Points: 88
What's the difference between the blue box and the wall? The light was like that when I took it down, in case that was not clear. It had a grey circle thing around the wires btw.
How do I add a junction box from the front side? *sighs*
Old 02-13-2020, 03:47 PM   #10
Rewards Points: 1,846
You say you hit some kind of box behind the hole, so maybe there is a box there and the drywall was never cut out to completely expose it. Post a picture if you can and maybe we can figure out if there is a box there.
The blue boxes are junction boxes and protect the wiring. If there is ever a problem that causes the wiring to heat up, it will protect a potential fire from spreading quickly to the surrounding wall. The electrical code requires all connections to be made inside a junction box or other approved enclosure. You can't just stuff the splice into the wall.
To install a new box, there are "old work" boxes that can be put in from the room side of the wall.
https://www.homedepot.com/p/Carlon-3...614R/100580105
RAL238 is offline   Reply With Quote
Old 02-13-2020, 04:27 PM   #11
Rewards Points: 88
To install a new partition, there are "old work" boxes that can be put in from the room side of the wall.
It was a wood type partition...I really don't know...since I just opened up the wall enough to shove those wires in. I'll have to do some research on how to put wires into that blue box. Is there an opening in the box somewhere?
Can the wires heat up if the light is not used?
Old 02-13-2020, 04:43 PM   #12
Usually Confused
lenaitch's Avatar
Rewards Points: 1,038
All electrical connections have to be made inside a junction box. Some lamp fixtures are certified as junction boxes but I highly doubt yours is. Having wires going directly into these types of fixtures isn't approved by certainly not uncommon.
Depending on where the wood "partition" (stud) is located may complicate cutting in an old work junction box.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
J. V. (02-16-2020)
Old 02-13-2020, 05:09 PM   #13
Rewards Points: 88
I have to stop DIY'ing for today, when I get back to it, I will remove the light and take pictures.
Old 02-14-2020, 06:41 AM   #14
Rewards Points: 590
check the directions that came with the light fixture. It will usually tell you if you can make your connections within the fixture itself. But the romex has to come thru the round hole have a strain relief (romex connector) and then the connections can be made within the box. If the instructions show this then the fixture was probably approved for connections to be made inside. Just be darn sure that no conductors are just sitting inside the wall without sheathing around them and of course no connections inside the wall without a box.
afjes2015 is offline   Reply With Quote
The Following User Says Thank You to afjes2015 For This Useful Post:
J. V. (02-16-2020)
Old 02-17-2020, 07:30 PM   #15
Rewards Points: 88
So I received the junction box. I'm not sure I got the right one.
I figured out where the wires come in...but what is the metal thing supposed to do?
I saw a Youtube video that shows a different one with tabs but then I heard those were hard to insert into the hole because the tabs stick out.
Curious why they attached ground wire to faceplate-junction-box-1.jpg   Curious why they attached ground wire to faceplate-junction-box-2.jpg   Curious why they attached ground wire to faceplate-junction-box-4.jpg
