Cubicles-single Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 06:42 PM   #1
Cubicles-single circuit
I wanted to put two cubicles in that I picked up. It has 8 wires and was originally set up for 3 phase + 1 dedicated circuit. Where I want to put it has only a dedicated single circuit. What is the best way to wire this? Can I take the 4 hots (pink red blue black) and connect it to the incoming hot, the two neutrals connected the the incoming neutral and the two grounds to the incoming ground?
platestealer is offline   Reply With Quote
Old 04-04-2013, 06:48 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,676
Do you have receptacles a-b-c and d?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 04-04-2013, 07:23 PM   #3
yes, there are receptacles A B C & D
Old 04-04-2013, 07:30 PM   #4
jbfan's Avatar
That's five wires under one wire nut for the hots.
It will work.
I would leave out the pink wire on the dedicated circuit and just use a-b-and c
The Following User Says Thank You to jbfan For This Useful Post:
platestealer (04-04-2013)
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Sizing Motor Branch Circuit Conductors and OCPD's electures Electrical 5 06-22-2011 11:32 PM
Different AWG in single circuit iceclimber2001 Electrical 11 04-15-2010 11:24 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
