Crawl Space Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 12:33 PM   #1
crawl space electrical
what does the code say about sub panels in crawl spaces ? I am in a three level split and the space is clean dry and easily acessable.
newjl is offline   Reply With Quote
Old 08-04-2010, 08:38 PM   #2
C22.1-09 CSA Electrical Code Book
26-402 Location of panelboards
(1) Panelboards shall not be located in coal bins, clothes closets, bathrooms, stairways, high ambient rooms,
dangerous or hazardous locations, nor in any similar undesirable places.
(2) Panelboards in dwelling units shall be installed as high as possible, with no overcurrent device operating
handle positioned more than 1.7m above the finished floor level.
macdonald is offline   Reply With Quote
Old 08-04-2010, 09:41 PM   #3
Electrician
Proby's Avatar
This is the problem when people don't fill in their location.
newjl, where are you from?? Be aware that macdonald is giving you Canadian code.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-04-2010, 09:44 PM   #4
Old 08-04-2010, 09:44 PM   #5
OP's IP tracks to Canada
Old 08-04-2010, 09:47 PM   #6
Electrician
Proby's Avatar
macdonald is psychic.
Old 08-04-2010, 10:04 PM   #7
No, I just wanted to make it understood I was giving Canadian code as no location listed. But I might go buy a lotto ticket.!!
Old 08-05-2010, 08:31 AM   #8
Panel
macdonald < many thanks for your reply . i am in ontario Canada . you have solved my problem .
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 11:16 AM
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 05:58 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
32 inch high crawl space can a furnace fit tommar HVAC 4 02-20-2008 05:28 AM
