Cover To Hide Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 10:43 PM   #1
Cover to hide wire?
We recently just put in new cupboards and put puck lighting underneath. The wire is not something I could not live with but there has to be something out there that can cover it and make it a little more attractive. Does anyone know of anything that would work?
ingeborgdot is offline   Reply With Quote
Old 08-04-2010, 12:01 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I don't care for Wiremold myself but it does serve a purpose.
I can't find a quick easy place to show you much but here is a pic of one type. It can be had in metal or plastic versions and a variety of sizes
http://www.google.com/products/catal...d=0CDsQ8wIwBA#
Old 08-04-2010, 05:01 AM   #3
It almost needs to be a material contour forming stuff. The wiremold will be tough to use.
Old 08-04-2010, 06:48 AM   #4
Rewards Points: 2,800
Seems to me the cover has to either look like a cover to hide wires, or must offer 1-1/2 inches of protection from driven nails or screws, witness the requirement that wires strung through the walls must be 1-1/4 inches in from the edges of studs. (Allow 1/4" for the wall covering which could be Masonite.)
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 08-04-2010, 08:52 AM   #5
nap
You talking to me?
nap's Avatar
I must be misunderstanding what you are doing then. What would this have to conform to? With wire mold, you cut it to fit straight runs and then you purchase 90 angles to turn it the direction you need to go.
maybe if you could post a pic of what you are trying to cover it would help.
Old 08-05-2010, 07:41 AM   #6
57_Hemi's Avatar
I assume u are talking about the wires linking each puck light to one another ?
How high are ur caninets installed ?
Im surprised u can see the wires (unless ofcourse they are left dangling)
Do you have a cabinet base deco trim piece installed ?
wire mould is a good idea (as stated in a previous post) or maybe even a type of flexible wire loom and a clip or two holding it up in place.
A pic would be better though.
let us know.....
57_Hemi is offline   Reply With Quote
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
Fishing Wire MikeyP Electrical 17 12-01-2008 10:05 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
