Countdown Timer, 2 Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 09:09 PM   #1
countdown timer, 2 wires
Hi,
I want to replace a switch with a digital countdown timer switch. The timer has three wires: black, red, white, while there are only two wires in the switch box: black and white.
The instructions say to connect black to hot, red to load and white to white.
How am I supposed to wire in this case?
thanks a lot.
olnoln is offline   Reply With Quote
Old 03-31-2010, 09:18 PM   #2
" Euro " electrician
frenchelectrican's Avatar
If you only have two conductors in the switch box then you have switch loop and I know some of the electronique timers must have netural to order to functon properly.
And in your situation there is no netural at all unless you have other pair of conductors in that switch box.
Merci,Marc
Old 04-01-2010, 09:46 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,978
You have a switch loop. There is no neutral. You need a different switch or you need to pull new cable.
Old 04-01-2010, 10:01 AM   #4
Just call me Andrew
Rewards Points: 1,032
There are countdown timers that do not require neutrals...like this one:
http://www.lutron.com/cms400/PageBuy...=16957&mn=1799
This one will have two terminals on it, you connect the black to one, the white to the other.
Andrew
secutanudu is offline   Reply With Quote
Old 04-01-2010, 02:53 PM   #5
Super Moderator
joed's Avatar
This no neutral won't work with CFL. Says incandescent or fan only. That means it feeds a small current through the lamp to operate.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
GE Smart Digital Timer Trevis Electrical 21 09-08-2011 10:17 PM
help wiring a timer in a 3 gang light box edadmartin Electrical 3 03-14-2010 08:05 PM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 07:11 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
