Correcting Existing Subpanel In Detached Garage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 04:07 PM   #16
Master Electrician
Rewards Points: 5,084
Originally Posted by Scuba_Dave View Post
Yup - Thanks, I found one Mfg that listed 8-2 as .580
I also measured some 8-2 & it is over 1/2" (measured without my glasses on )
That would be a tight squeeze into 1/2"
I missed the fact the info I had was cross section & calculator wants diameter
Cool!
brric is offline   Reply With Quote
Old 03-14-2010, 07:57 AM   #17
mtk
Rewards Points: 18
The cable has black sheathing on it and I am 99% sure it is 8-2
The conduit leading from the junction box on the wall to the panel is definitely 1/2. But I am not completely sure what is underground. The junction box isn't easy to get to at the moment, but when I pull the new wire I will let you know and see if I can take a pic of what is stuffed in there!
Thanks for your help.
mtk is offline   Reply With Quote
Old 03-14-2010, 01:49 PM   #18
mtk
Rewards Points: 18
I plan to put in the two ground rods at the garage.
Since there is plumbing out to the garage, should the ground there also be tied to the plumbing?
Thanks.
detached garage subpanel help edmart2 Electrical 7 03-19-2009 12:01 PM
Subpanel - detached garage without a floor SAS Electrical 12 03-05-2009 11:42 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 03:27 PM
Subpanel Questions/Running electrical to garage. FlyGuy Electrical 28 05-24-2008 10:50 PM
